Heater Question
Old May 9, 2018 | 09:27 PM
F100 '64's Avatar
F100 '64
Heater Question
Hello all, I just finished repainting the heater box and replacing the blower motor on my truck (64 F100). When I bought it many parts were missing including the drive train.
So my question is how is the temperature controlled? The box has a lever to change from floor to defroster, and a lever that closes the plenum from the heater core area to the floor/defroster vents.
Thanks in advance...Pat
Old May 10, 2018 | 07:27 AM
john jamieson's Avatar
john jamieson
Besides the fan speed, there should be a valve inline on one of the hoses going to the heater. On some trucks it is cable controlled from the dash.
On mine they are manual.
Old May 10, 2018 | 07:53 AM
Tedster9's Avatar
Tedster9
The fresh air DeLuxe heater, an extra cost option, the coolant flow to the core was controllable from inside the cab.
Pretty dang decadent huh? There will be three levers on trucks so equipped - the 2 speed fan switch, also controls the floor or defrost vents by pulling out, then there are two more - Heat and Temp levers, that I can never remember which one does what. "Heat" draws outside air instead of simply recirculated air iirc. I will say with a 195° F thermostat the heat works really well considering there was no insulation to speak of in those days. Good heaters.
Old May 10, 2018 | 09:58 PM
F100 '64's Avatar
F100 '64
Thanks guys, mine does have the fan/heat-defrost lever in the dash and two more levers mounted to the bottom of the dash. After looking more closely at these two, one goes to the plenum I mentioned before and the other was not attached to anything just hanging below the dash. I'm thinking that may be the one to go to a valve to close off the antifreeze flow to the core.
Old May 10, 2018 | 10:18 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
B8C-18495-A (replaced FDU-18495-A) .. Cable Controlled Heater Water Valve-Use with Deluxe Fresh Air Heater; Located on Right Front Fender Apron (trucks) (Motorcraft YG-134) / Obsolete
1957/64 F100/1100 / 1963/64 N/NT500/1100 // 1956/57 Lincoln. Shown as 18495 in pic.
LINCOLN-MERCURY OLD PARTS STORE in Clearwater FL has 2 = 727-445-7551.
Old May 12, 2018 | 05:32 AM
66ordie's Avatar
66ordie
I have all of this available from my 66 as I am replacing it, if you are in need just let me know
Old May 12, 2018 | 07:50 AM
NumberDummy
Not the same parts, the 1961/64 deluxe fresh air heater is different than 1965/66.
Old May 12, 2018 | 11:53 AM
skidoorulz's Avatar
skidoorulz
You are correct. it goes through the firewall below the battery box and to the valve mounted on the right inner fender.
troymn
Nov 16, 2017 09:47 PM
gooey69
Feb 15, 2010 01:34 PM
germans1966
Nov 7, 2009 07:04 AM
handx2
Mar 25, 2004 05:27 PM
