ZF conversion and ... carpet!
Old May 6, 2018 | 11:21 AM
F-250 restorer's Avatar
F-250 restorer
I have a 75 with column shift for a c6 auto. I'm converting to ZF 5 trans. I see that LMC has diff carpet for the diff trans, due to configuration of the trans tunnel. Will I need to change carpet once the tunnel is reconfigured? Thanks.
Old May 6, 2018 | 08:03 PM
bryanmartin's Avatar
bryanmartin
The difference is in 2wd vs 4wd and trans type tunnel profile. Unless you're swaping trans tunnel covers, go with the carpet that will fit your rig in it's current configuration. The ZF5 shifter may sit in a different location, but replacement carpets all come without shifter holes cut in them anyway. That is something you'll have to do yourself.
TOsborn
Dec 7, 2017 03:36 PM
lownslowslick4
May 12, 2011 04:55 PM
gbrett
Dec 11, 2006 06:40 PM
murphy
Jan 6, 2005 07:32 AM
systemofadowntox
Jul 21, 2004 10:21 AM
