What's a toploader trans ?
Old Jan 5, 2005 | 03:24 PM
murphy's Avatar
murphy
In regards to ford, what are they, why the name ?
Old Jan 5, 2005 | 04:29 PM
Madathlon's Avatar
Madathlon
A top Loader Trans is a trans with the shifter built right in the top of the trans.. IE: T18, T19, T98, And T98A Are all top loaders
Old Jan 5, 2005 | 04:44 PM
dlister's Avatar
dlister
Well, actually top loaders go way back. They were called top loaders because the access plate was on the top (3 speeds, 4 speeds). while most GM loaded from the side as did lighter ford transmissions. They usually had plates machined on the tail housing to bolt on the floor mounted shifter. These where considered very tough.
Old Jan 5, 2005 | 07:18 PM
286merc's Avatar
286merc
There are top loaders and Top Loaders. The latter refers to the RUG series Ford built 4spds of the muscle car era. These were offered behind everything from a 6 banger to a 427 cammer.
Old Jan 6, 2005 | 07:32 AM
4tl8ford's Avatar
4tl8ford
Check out the link below for a good explanation
http://www.4speedtoploaders.com/
