I am trying to get my 66 f100 truck mechanically sound before i completely assemble it.
I Yesterday i received my new flasher emergency switch and i installed it.
I tried to turn on the signal lights and only one side on the dash lights up. If i turn on the flashers, both lights on the dash light up. So a least i know the signal bulbs are not burned out and are functioning.
I do not have any tail/signal lights hooked up,
Front signal lights are just dangling off the firewall. they do not light up.
At the flasher relay, i do have power coming in. No idea if my flasher relay is any good. However, i did try a few others.
I think someone will tell me the answer is to put the truck together they try again after all grounds are installed.
Thanks
Reason: added words
Well, it is true that the housing for the front and rear lights is also the ground plane so the housings MUST be grounded in order to have a complete circuit. At a minimum a jumper wire from the housing to ground. They just ain't gonna work without that.
And may need both bulbs, front & back wired into the system as the flashers work on load and with 1 bulb may not be enough load to work the flasher.
Dave ----
