1978 - 1996 Big Bronco
Signal lights
Old Jun 28, 2012 | 11:18 PM
Zip's Avatar
Zip
Signal lights
I am having an issue with my signal lights. I have none. No front park lights either. Four way flashers work front and back. When I turn on the lights both signal indicators light up. When I put the lever into a signal position that indicator light will go out.
Something is haywire. Short or ground, something else?
Old Jun 28, 2012 | 11:48 PM
429unibody's Avatar
429unibody
Un plug all the connections up to the signal lights and start plugging them in closest to the firewall and you should find the problem that way .I had similar problem with my 64 and the harness was squished between the rad support and rad
Old Jun 28, 2012 | 11:54 PM
Zip's Avatar
Zip
Hey, how's things. I'll give that a shot. I have the same problems with both my 65 and 66 sort of. Signal lights work on both but no park lights on the front. I fiddled with the 65 and had them working for a bit then they quit again.
I am going to have to pull the steering wheel and check for power there. I have no power to the flasher, which I think I should have with a signal activated.
Old Jun 29, 2012 | 07:48 AM
429unibody's Avatar
429unibody
Sometimes the light bulb housing needs to be cleaned up too. I just went back to work after two months off,we got 2/3 of the sheeting done on the shop hoping to get it finished this weekend!
Old Jun 29, 2012 | 01:07 PM
Zip's Avatar
Zip
I've seen it on facebook. Looks pretty good.
BigCountry1978
15
Sep 3, 2025 08:33 AM
rcw3023
1983 - 2012 Ranger & B-Series
Jan 10, 2017 10:54 PM
Padra
Jun 13, 2012 10:10 PM
bad_habit59
Jan 23, 2009 01:53 PM
rogerranger
Nov 28, 2003 10:13 PM
