T18 Question
Old May 4, 2018 | 12:42 PM
applebaggins's Avatar
applebaggins
Question T18 Question
Hey folks - novice mechanic looking for some help.
I have a 4 speed 1978 T18 Ford transmission I've pulled and am working on. I had to take it to a garage to get the yoke nut off - I had both gears locked into place when the mechanic took the nut off. Everything seemed ok.
I got it back home and I can shift the first gear into neutral, but I can't get the third gear into neutral.
There's a little play back and forth in the whole shaft - doesn't seem too big.
When I rotate the input or output shaft, there's a constant clunking noise and every now and then, the gears bind up and won't rotate. I can rotate the shaft back and forth and eventually keep rotating the gears.
Am I looking at a busted bearing? Whatever happened, it seemed to coincide with the mechanic taking the yoke nut off while both gears were locked in.
Thanks for your help!
Old May 8, 2018 | 08:27 AM
SSStang's Avatar
SSStang
Sounds like a gear lost some teeth and maybe a bearing. Only way to tell is take it apart.
applebaggins
May 8, 2018 10:08 AM
Blueranger91
1983 - 2012 Ranger & B-Series
Aug 1, 2016 09:12 AM
bryanmartin
May 15, 2015 05:59 AM
rparsons1000
Jun 10, 2002 06:05 AM
MarkMe
May 15, 2000 03:52 PM
