5 speed knocking
Old Aug 1, 2016 | 08:29 AM
Blueranger91's Avatar
Blueranger91
5 speed knocking
I have a 1991 ranger 4.0 5 speed. It is making a loud knocking noise in all the gears except for fourth. I believe it is the input shaft bearing? I was going to rebuild the whole thing but then I found a input shaft repair sleeve on rock auto. Was wondering if it would be worth trying first, And how difficult a job it would be?
Old Aug 1, 2016 | 08:38 AM
tomw's Avatar
tomw
Contrary, the 'counter shaft' is engaged and loaded in every gear but 4th. It is used in OD to transfer power to the rearmost gear, which transfers then to the OD gearset. It is used in all reduction gears. In 4th the input shaft and output shaft are locked together, so the counter gear is not loaded in any way. The knocking is likely due to failed needle bearings internal to the counter shaft gear.
I'd bet on counter shaft bearings. The input shaft bearing is loaded in all gears, forward and reverse. You do the math.
tom
Old Aug 1, 2016 | 09:12 AM
Blueranger91
Thanks Tom,
thefasteddy
Mar 9, 2021 05:42 AM
jason832
Feb 11, 2018 06:50 PM
one2dog
Aug 28, 2016 08:18 AM
quakerj
Jan 15, 2014 08:50 PM
fordxxx
Jan 2, 2006 09:58 AM
