Need help installing window felts
Old May 2, 2018 | 06:09 PM
bryanmartin's Avatar
bryanmartin
Hi, I'm putting in my weather strip, but I'm not sure how these glass-run window felts go in. Specifically, where do they terminate on the top end? Am I supposed to trim them off right at the vent window, or do they get sandwiched between the vent window and the frame? This is the area I'm talking about.
As you can see, the felt is long enough that it continues under where the vent window mounts. Am I supposed to trim it off at some point? The other end is right at the end of the window run channel, so it wouldn't make sense to just pull it back the other way.
Last question, do these get glued in? They seem to be holding just fine for now, but I want to make sure they don't fall out.
Thanks!
Old May 2, 2018 | 07:51 PM
hickory1991's Avatar
hickory1991
See if this video helps you out. https://www.prp.com/product/detail/1...F-250&type=All
Old May 2, 2018 | 08:21 PM
bryanmartin
Originally Posted by hickory1991
Perfect! Thank you!
Old May 3, 2018 | 12:56 PM
CelticOne's Avatar
CelticOne
Regular User
I used that same video to install mine.
The long piece will START at the vent window frame (which you don't have installed it seems) and proceeds along the top and down the back of the door as far as they will reach - no trimming.
The second piece starts at the top of the vent window frame and goes straight down that frame.
No glue needed.
Old May 3, 2018 | 10:19 PM
bryanmartin
No glue needed.
The vent window has been in and out. Thanks for the info!
jrockdiddy
16
Oct 3, 2019 05:47 PM
rsh1966
Jul 20, 2019 12:12 AM
Broncor
Jan 23, 2019 06:09 AM
94MustangGT
Aug 1, 2010 12:18 AM
