VIN # Help needed
Old May 1, 2018 | 08:39 PM
Larrymac52's Avatar
Larrymac52
VIN # Help needed
so I’m looking at the Mike Murphy Ford site where I can enter the Vin# to see the window sticker. I’ve actually done this before. My truck’s build date was supposedly 5/19-5/25.
Well, I was just going thru the motions and the window sticker popped up unexpectedly.
I’d post the Sticker but there is a grey image covering most of the sticker. ( whether I use the phone or computer.) Is there another site I can see the entire sticker without the gray blackout — or how do I eliminate the blackout as the sticker is obviously underneath it?
The sticker does say at the bottom:
Ramp one RA29, transport by rail.
line near bottom says:
JD301N RB 2X 840 001888 04 30 18
Date on bottom of sticker says today’s date
05/01/2018.
Can anyone interpret these numbers with expected build date, and potential arrival at the dealer?
Seems to be happening faster than expected, and I’m probably the first not wanting this to happen
Also how do I get rid of this gray blackout covering most of the sticker? Thank you
Old May 1, 2018 | 08:50 PM
1olddogtwo's Avatar
1olddogtwo
Have you checked your monitor ink reservoir late?
That should clear up, mine did that for a couple of days.
h20camper's Avatar
h20camper
Try this URL replacing your VIN at the end.
http://www.windowsticker.forddirect....7W2BT4HEE30855
You can also right click on Mike Murphy's site in the top box and select Save As or Print.
Old May 1, 2018 | 08:52 PM
davidpacificnw's Avatar
davidpacificnw
add your vin after the = symbol in this url
http://www.windowsticker.forddirect....icker.pdf?vin=
Old May 1, 2018 | 09:10 PM
Larrymac52's Avatar
Larrymac52
never heard of that? How is that done?
Old May 1, 2018 | 09:17 PM
Larrymac52's Avatar
Larrymac52
It did not work for me
Old May 1, 2018 | 09:19 PM
Larrymac52's Avatar
Larrymac52
didn’t work— said window sticker has not been released, but obviously it has.
the Murphy site worked, just can’t get rid of the blackout over most of it. Anyone know the secret?
Old May 1, 2018 | 09:20 PM
Larrymac52's Avatar
Larrymac52
Ok finally got a clean window sticker.
Anyone know how to interpret the numbers and dates that I mentioned in the OP?
Build date?
potential arrival at dealer?
Old May 1, 2018 | 10:26 PM
davidpacificnw
Build date?
Larry,
if you don't mind me asking, when did you order your rig? Mine supposedly has a build date of May 8th, but I still don't have a window sticker. thanks
Old May 1, 2018 | 10:51 PM
Larrymac52's Avatar
Larrymac52
Larry,
David:
If I remember correctly, my order date was a couple days before you, 3/21/18. Build date was initially 5/19-25. I don’t know how to interpret the numbers on the sticker, but it appears this is happening faster, and I’m probably the only guy not wanting it to be faster.
Old May 1, 2018 | 11:06 PM
davidpacificnw
David:
hmmm. That's odd as I've seen my order summary and it has Priority code 01 on it. Your sticker came up on the Ford Direct site? Or the Mike Murphy site?
Yeah, I really need this rig as my TT is in transport now. Oh well. not much I can do about it. I guess I just wait more. keep us posted.
David
Old May 2, 2018 | 12:50 AM
Larrymac52's Avatar
Larrymac52
David
sticker came up on both sites. Your dealer should know more. Contact them ASAP
Old May 5, 2018 | 11:08 AM
davidpacificnw
Larry,
Just got my sticker today. No ideal wha the numbers mean. My dealer says build date is 05/13. My method of transport says "convoy". breaker breaker good buy. LOL
Grassman09
Sep 11, 2011 02:00 AM
blueheron
6.7L Power Stroke Diesel
Sep 3, 2010 04:26 PM
KC8QVO
Jul 27, 2010 06:47 AM
F-1Fiddy
2009 - 2014 F150
Jun 4, 2010 08:52 PM
mantta
2009 - 2014 F150
May 20, 2010 07:04 PM
