Transmission lines
Old May 1, 2018 | 02:18 PM
F0rdF0rever's Avatar
F0rdF0rever
Transmission lines
Ive searched for the part numbers with no success. I need to replace the two lines going from the transmission to the external filter and the one line going from the drivers side of the radiator to the trans cooler due to rust.
Does anyone have part numbers for these?
Old May 1, 2018 | 02:24 PM
Sparky83's Avatar
Sparky83
i think most people just get the replacement lines from like autozone or somewhere like that... with your year youll have the quick disconnects on rad side..
Old May 1, 2018 | 02:41 PM
bismic's Avatar
bismic
I have these numbers that might get you started in a search. I didn't document the specifics very well though. good luck w/ searching. post up what you end up with!
Transmission cooler line...3C3Z-7890-CA
Transmission cooler line...4C3Z-7B028-CA
Transmission cooler line...6C3Z-7R081-CA
Transmission cooler line...6C3Z-7C410-AA
https://www.tascaparts.com/oem-parts...ler-3c3z7890ca
https://www.tascaparts.com/oem-parts...er-4c3z7b028ca
https://www.tascaparts.com/oem-parts...sy-6c3z7r081ca
https://www.tascaparts.com/oem-parts...er-6c3z7c410aa
Old May 1, 2018 | 03:17 PM
TooManyToys.'s Avatar
TooManyToys.
This is an ad for the ‘03 two long tubes, Trans to filter. The pics also show basic numbers and their locations.
https://www.ebay.com/itm/BRAND-NEW-F...4383.l4275.c10
Old May 1, 2018 | 03:38 PM
bismic's Avatar
bismic
Since his is an 06, he will probably want the 6C3Z version
Old May 1, 2018 | 04:11 PM
F0rdF0rever
Thanks for help guys. Got em ordered from Tasca.
The radiator to cooler is 6C3Z-7C410-AA
The Trans to cooler FILTER lines are 6C3Z-7R081-F
Old May 4, 2018 | 01:56 PM
F0rdF0rever
My replacement lines came in today. Going to install them tomorrow. How much fluid can I expect to lose?
Old May 4, 2018 | 06:23 PM
69cj's Avatar
69cj
Change the external filter at the same time and app. 8 qts. 8 oz.
Old May 4, 2018 | 07:10 PM
F0rdF0rever
Good idea. I didnt think of that. Wonder if I can find a filter locally.
Old May 5, 2018 | 07:20 PM
F0rdF0rever
Any tips for removing the nut that holds the trans lines above the oil pan? Thats in a really tight spot! And mine is rusted solid.
Old May 5, 2018 | 08:19 PM
TooManyToys.
Many unbolt the pass side engine mount bolts and jack the engine up a little.
Old May 5, 2018 | 09:22 PM
F0rdF0rever
Is it that simple? Unbolt the passenger side mount and jack the engine?
Old May 5, 2018 | 09:44 PM
Per4mance's Avatar
Per4mance
Funny this thread came up, I'm doing the engine in my brother's truck that is a rusty mess and it needs tranny lines badly. I wonder if the part numbers are the same for the 5.4 trans?
Old May 6, 2018 | 10:52 AM
F0rdF0rever
Got the old ones out and the new ones in. That a tight fit! I was able to feed the new ones in from the front after getting the drag link out of the was.
I ended up breaking the bracket under the pan off.
I didn't take note of which line goes where on the filter housing.
Anyone know which port the shorter line goes to?
Old May 6, 2018 | 05:27 PM
F0rdF0rever
I finally found a diagram on the Google. Shorter line in on left of the filter. Longer to the right.
I'm glad that's over with. Was not fun.
For anyone thinking of doing this. Buy the metal tool for the quick connect fittings. That little plastic one just wouldn't do it for the rusted fittings.
palacios289
Dec 27, 2018 07:26 PM
TA455HO
22
Oct 8, 2017 12:05 AM
enriched&beyound
Feb 7, 2017 07:36 AM
lasermike
Jan 22, 2017 10:56 PM
itsjustdan26
Jun 18, 2010 10:30 AM
