Distributor/ Timing Questions
Old Apr 30, 2018 | 09:28 PM
GiggityBurns's Avatar
GiggityBurns
Question Distributor/ Timing Questions
So I bought my truck used from a guy who seemed to generally take care of the truck mechanically. New plug wires, new spark plugs (haven't verified that), and new distributor cap. Anyway, I went to get the truck to get a smog, and had to drive on the freeway for a few miles, so the truck was at operating temp. I get there and shut it off for it to not turn on again. I know that lots of people have the hot start issue, but that is not my question for this tread. After letting it cool down, the truck would die if I let go of the throttle. Of course, that led to the hot start issue. The smog guy was nice enough to advance the timing by turning the distributor a little (I had no clue what he was doing), and that seemed to make it start (still struggled to) and run normally. I do not know much about advancing/ retarding timing, I just know the basics of how a distributor works. My question would be why did that help the truck run better when hot after advancing the timing? Is there anything I should know about when someone advances the timing? Do I have to retard it back to normal, or do I just leave it?
Old Apr 30, 2018 | 09:37 PM
Tedster9's Avatar
Tedster9
Welcome to FTE
For all we know maybe he retarded the ignition timing.
I think the thing to do though, is verify for yourself that the timing is correct, and distributor is operating correctly, to include vacuum advance. The base timing is actually just a small part of the overall picture.
Old Apr 30, 2018 | 09:50 PM
GiggityBurns
Originally Posted by Tedster9
Welcome to FTE
Not trying to sound stupid (even though I kind of feel dumb) by saying this, but mind you I have no clue what you said there . It's fine if you don't have the time to explain, but like I said in the original post, I barely know what a distributor does and what it means to advance and retard the timing with it (although I don't know all the procedures of doing so). Thank you for your help
Old Apr 30, 2018 | 10:08 PM
Tedster9's Avatar
Tedster9
No, that's not a problem everybody started from the same spot on this stuff. You will need a timing light and some other basic hand tools to get started. Did it pass smog btw?
Old Apr 30, 2018 | 11:25 PM
GiggityBurns
The guy who happened to helped me with my distributor said he doesn't trust my truck (assuming he's talking about the hot start issue) and to come back after I get it fixed. But it did pass smog under the last owner last September
Old May 1, 2018 | 01:40 AM
Tedster9's Avatar
Tedster9
Ok, sounds like he helped you get it started again but declined to actually test it for smog?
Anyway one of the symptoms of the initial or base timing being too far advanced - is hard starting - particularly when hot or fully warmed up. Known as starter kickback. You can test for this condition if it happens again. The next time it's good and warmed up or the problem has presented itself disable the ignition and see if the engine turns over normally.
Old May 5, 2018 | 01:01 PM
Deadulus's Avatar
Deadulus
I don't mean to hijack this thread, but I'm having similar issues. By disabling the ignition, do you mean something as simple as unplugging the coil wire and trying to start? *we now return to normal programming*.
Old May 5, 2018 | 01:24 PM
Tedster9's Avatar
Tedster9
Yep, though it should probably be grounded so to prevent the possibility of internal damage.
Too much initial advance and the starter will be fighting against early combustion in cylinders..
Old May 5, 2018 | 01:30 PM
Deadulus's Avatar
Deadulus
Ah! Ok, thank you!
Old May 7, 2018 | 06:41 PM
GiggityBurns
Talking
Thank you, I know everyone starts somewhere, but I know how it is to explain something you find simple that I find difficult. again, than you so much!
earthquake68
28
Mar 19, 2015 11:27 PM
LilBear'65
16
Mar 12, 2015 10:16 PM
RocketmanVT
Dec 30, 2012 05:04 PM
ralph54
Oct 11, 2010 06:49 PM
OrionsIce
1983 - 2012 Ranger & B-Series
Jan 5, 2003 11:46 AM
