Ac vacuum selector switch part number w/ compressor question
Old Apr 29, 2018 | 10:55 PM
83sd's Avatar
83sd
I recently picked up a 74 f100 factory ac truck. Last week I was able to confirm that the system was still full of r12 and the expansion valve will get cold when run. The blower turns on, but I have no air from the vents. I opened up the dash to take a look and found the vent selector vacuum valve to have come apart. This obviously happened some years back and they just disconnected the vacuum line under the hood. Looking on line, there are several options for the valve. Lmc lists two factory part numbers that do not match mine. My valve has D3TAI9B919 ac on it.What is the correct valve?
I wanted to check the oil level in the compressor, but mine does not have service valves on top. This would mean I cannot check it without losing the charge, correct?
Old Apr 30, 2018 | 06:49 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 83sd
I recently picked up a 74 F100 factory A/C truck. Last week I was able to confirm that the system was still full of R-12 and the expansion valve will get cold when run. The blower turns on, but I have no air from the vents. I opened up the dash to take a look and found the vent selector vacuum valve to have come apart. This obviously happened some years back and they just disconnected the vacuum line under the hood. Looking on line, there are several options for the valve. Lmc lists two factory part numbers that do not match mine.
My valve is marked with ID engineering number: D3TA-19B919-AC
D5TZ-19B888-A (replaced D3TZ-19B888-A) .. A/C Vacuum Controlled Selector Valve Assy - Marked: D3TA-19B919-AA or AB or AC (Motorcraft YH-285) / Obsolete
1973/79 F100/350, 1978/79 Bronco.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 65 = 800-476-9653.
Pic: Illustrated as 19B888 at lower left.
Old Apr 30, 2018 | 07:59 AM
mikeo0o0o0's Avatar
mikeo0o0o0
You should have a York compressor. The oil level in those are checked through a service port in either the side (vertical mount compressor) or the top (horizontal mount compressor). You can fab a dipstick out of a piece of wire.
Here's a link to the York service manual. It gives you all the info you'll need. Page 7 has the oil level info.
P.S. Your control valve coming apart is a real common problem.
File Type: pdf
Old May 8, 2018 | 10:09 PM
83sd's Avatar
83sd
Sorry for the delay in reply. Thank you both! got the valve ordered and installed. The hot cold valve came apart as soon as i messed with it, but that one can at least be bypassed with a single vacuum line. System comes to life and makes mildly cool air. Txv gets very cool. Going to check pressures and add some r12 if needed. Prior to that I plan to put a new blower motor in and clean everything out.
Old May 10, 2018 | 03:57 AM
Ozzie H.'s Avatar
Ozzie H.
You might be able to "capture" the R12, check the compressor's oil, add service valves and a sight glass to aid in charging, and reuse the charge.
AK FORD GUY
13
Mar 3, 2023 12:23 AM
bigperm2
Feb 28, 2016 06:53 AM
TommiFIN
13
Aug 8, 2013 09:49 AM
77 ford shortbed
Jun 6, 2009 07:56 PM
77 ford shortbed
Jun 6, 2009 06:43 AM
