5.4 death?
Old Apr 28, 2018 | 07:40 PM
Tritonhell's Avatar
Tritonhell
5.4 death?
I had what felt like a hydro lock recently during a restart after a stall. I also had a noisy drivers cam phaser and a 3045 code so I popped off the valve cover hoping a tweaked phaser caused the timing to be off and that caused the sudden resistance my starter felt. Phaser doesn’t look obviously tweaked. Then I checked cam journals. Popped two caps. Front was fine. Second one was scored. Ridges my fingernail could feel. I think I need a long block. Anyone run these with slight scoring?
thanks for reading.
Old Apr 29, 2018 | 08:56 AM
steve(ill)'s Avatar
steve(ill)
scoring normally results from lack of oil ( oil pressure)... weak pump or leaks thru the phaser system may have caused this... If you continue to run, I think long term your looking at bigger problems. You probably don't need a long block, but you do need additional inspection / pump / timing chain / gears / phaser or delete, and additional inspection of the cam shafts.
Old Apr 29, 2018 | 10:49 AM
Bent6's Avatar
Bent6
I had the exact same issue 150 miles from home with a car trailer when the engine stalled and was locked up when trying to restart it. After it cooled, I was able to restart it. I pulled the plugs off the VVT solenoids, and was able to make it home. Within 500 miles the timing chain was slapping the timing cover. Disassembly revealed that the head's cam journals were melted on the passenger side. I wound up with a reman engine with warranty for $3200.
Old May 9, 2018 | 12:19 AM
rwoodhull's Avatar
rwoodhull
Need to check oil pressure while engine is hot (200 degrees cylinder head temp). Once engine is hot power brake in reverse @ 1200 RPM for 1-4 seconds and let off. Wait 10 seconds and repeat. Do this 10 times and let vehicle idle. If oil pressure ever drops below 18psi you are on borrowed time. Drive it until she blows.
Old May 16, 2018 | 04:08 PM
ojai150's Avatar
ojai150
If you don't mind, what difference does it make if you power brake it in reverse, or forward ? Just curious,....
Old May 16, 2018 | 05:40 PM
rwoodhull's Avatar
rwoodhull
It's the best way I have found to get a faulty vct solenoid to act up. Just my experience. It may be subconscious, don't want to slip off brake pedal and drive into my toolbox.
Old May 17, 2018 | 01:45 PM
Tritonhell's Avatar
Tritonhell
Thanks for the input. Here’s more info. After the weird resistance I felt trying to restart (after it stalled) it started but ran like a dog. Stunk of fuel. It felt like a hydro-lock so I thought an injector stuck open and bent a rod on the restart attempt. Then I saw the cam sensor code and decided (because it was less catastrophic) the phaser had finally sheered the pin and the timing being off was the weird resistance for lack of better term. It felt really bad. Like hydro lock or spun bearing in hindsight.
So I checked phaser and cam journals as mentioned and ithere was some scoring. Enough to feel with fingernail. My next move is to check compression. If one bank is all low I’ll pull off the front cover and check the timing. If one cyl is low I’ll figure a bent rod.
As im writing I’m realizing I should’ve started with injectors. Got sidetracked. Ugh.
Also, I replaced the timing chain, guides, tensioners and one phaser couple years back. Left the drivers phaser and had cam sensor code on same side.
It wont start anymore so can’t check oil pressure.
Then... got under the beast and found rot on back of frame where shackles n bumper brackets attach. I thing big red is all done. Thanks for reading
bschn140
2004 - 2008 F150
Jan 15, 2019 02:57 AM
patl111
2004 - 2008 F150
May 24, 2015 05:34 AM
Laura.311
2004 - 2008 F150
Mar 28, 2015 10:44 AM
fishnowworknever
2004 - 2008 F150
Oct 28, 2013 05:13 PM
BStreett
2004 - 2008 F150
Oct 21, 2011 07:05 PM
