Do I need a new motor?
Old May 23, 2015 | 11:43 AM
patl111's Avatar
patl111
I have a 2008 FX2 5.4L F150. Recently it began to lose power on a friend driving it out of town. He got a check engine light then it just progressively became unable to produce power. It ran but he got down to 10 mph before he could get to a firestone. I got it to a local Ford dealer and they say i need a new engine. They gave me codes for cam sensor and timing and #5 and #6 misfire. (344, 345)
No oil in radiator, no water in oil. The crazy thing is it runs like the day i bought it in Park. But once in gear it begins to cough and then eventually shudders and dies. I haven't changed plugs ever. I know... at about 75 miles it began to idle rough at times and in reverse. But once I revved up it went away.
I replaced both cam sensors but no luck. Today i put it on a tow truck to get a second opinion from a local engine shop. I actually backed it down my driveway, and pulled up to the tow truck with no issues. weird...
MY research tells me the cam issues are causing these problems pretty regularly. Anyone provide some insight?
Old May 23, 2015 | 03:15 PM
06mikes's Avatar
06mikes
Probably need to go after the timing, change oil pump while you are at it and vct solenoids ( oem).
Old May 24, 2015 | 05:34 AM
07F150Lariat5.4's Avatar
07F150Lariat5.4
For it to lose that much power, probably has jumped time. Before any timing work is done, check oil pressure at hot idle. Supposed to be 25 PSI. If below that, changing out timing components is just a waste of time and money.
Bruce184
Modular V8 (4.6L, 5.4L)
Aug 31, 2018 05:27 PM
jhruban80
2004 - 2008 F150
May 31, 2018 09:32 AM
Tritonhell
2004 - 2008 F150
May 17, 2018 01:45 PM
dexterslab724
2004 - 2008 F150
Aug 12, 2017 12:51 PM
Mikecdmd
2004 - 2008 F150
16
Sep 15, 2016 11:16 AM
