Injector swapping
Old Jun 7, 2018 | 04:05 PM
  #31
Bonanza35's Avatar
Bonanza35
Did I read right that it took 10 seconds to get oil pressure on the gauge? If that's so, I'd change the low pressure oil pump. You should get oil pressure way before that. At least I do. Do you know your low pressure oil pressure? There's been more than one guy over the years that had to do that if what I read is true. With the Ford scanner do you know your HPOP pressure when running down the street? Seems if it ran for 40 minutes at idle with new injectors, it should run with enough oil going to them. Did you try the Texas chapter for help. Use to be a big club there.
85Supclub
Aug 12, 2025 04:58 PM
Onus
Oct 14, 2012 07:01 PM
Jeremy2792
Oct 22, 2010 01:45 PM
GreatWhite99
Jan 1, 2009 04:32 PM
TN97STROKE
Apr 29, 2008 04:46 PM
