Is there a way to adjust the front bumper? My bumper is about 1 1/2" to the right, and is about 1/4" from touching the left side fender. I saw the bolts that are holding a plate or something under the radiator and are attached to the frame. Would those be used to adjust the bumper side to side?
The horns are part of/are the frame. So no it is not adjustable, unless you strap it down to a frame machine.
So either the bumper is wacky , the front clip is not adjusted correctly or the frame is bent.
Take your pick.
Glad you posted the photo, Mr. NumberDummy. %001A06 shows what the small air dam / spoiler looks like. My truck and my son's 1984 came with those. You don't see them very often.
I did not know they had a spoiler. Do both truck have AC?
You got pictures of it installed?
Dave ----
I did see the pictures on Gary's site, thanks for posting them here also.
I asked if AC or not because trying to figure out when it might of been used.
Also how does it attach, bumper or bottom of radaitor support?
Last question what is it made of?
Thanks
Dave - - - -
Now the last question LOL
How long is the lip from where it "bolts" to the bumper?
I might look in to making some thing from an old plastic car bumper cover.
thanks
Dave - - - -
I was wrong about it being made out of hard rubber... I believe it is plastic.
It is made in an "L" shape with the longer leg of the "L" being 1 1/8" wide. This is the side which has the 6 slotted holes in it and mounts to the bottom of the bumper. The leg of the "L" which extends downward is 1" wide. The overall length is 50 1/8" and the outer ends have a radius for 1".
The Ford partnumber is: E1TZ-10001A06-A Fixed it for you...
E1TZ-10001A06-A .. Front Air Deflector-Use with fuel economy package / Obsolete
1981/86 F100/350.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
GREEN SALES CO. in Cincinnati OH has 7 = 800-543-4959.
