Water pump
Old Apr 24, 2018 | 11:27 PM
riverstroker04's Avatar
riverstroker04
Water pump
Ok so I have an 04 350 all the work done to it just not the water pump and it's going out 99k on her, question is do you put a factory one back in it or the bulletproof Billet aluminum???
Old Apr 25, 2018 | 07:21 AM
bismic's Avatar
bismic
Is it an early 04 or late 04 truck (ie do you have an 03 engine)?
Old Apr 25, 2018 | 10:32 AM
AGE mechanic's Avatar
AGE mechanic
That's a no brainier to me. Put the BPD one in.
Old Apr 25, 2018 | 12:04 PM
riverstroker04
it's the late 04 bismic.
Old Apr 25, 2018 | 01:28 PM
Ford.Dude's Avatar
Ford.Dude
I went with a bulletproofdiesel. Great quality product. Go with one that has a metal impeller imo. I've heard the oem plastic ones can come apart and I didn't want another risk.
Old Apr 25, 2018 | 02:56 PM
riverstroker04
good info thank you, that's one reason why I was thinking BPD is there other ones with metal impellers other than BPD?
Old Apr 25, 2018 | 03:48 PM
bismic's Avatar
bismic
I believe that the early 04's had the 90mm impellors. The late 04's will have the (better) 100mm design. To upgrade from a 90mm pump to a 100mm pump (which you are not doing) you would have needed a front cover also. I was just checking.
Old Apr 25, 2018 | 03:58 PM
riverstroker04
thanks, what is your thought on the pumps?
Old Apr 25, 2018 | 04:05 PM
bismic's Avatar
bismic
I really don't have a strong opinion. I don't think the OEM's are all that bad, but that is just me. Having said that, I am running one from BulletProofDiesel .... mainly because I was one of several folks that was given the pump to test. I like it, good quality! I certainly will recommend it based on my experience.
Old Apr 25, 2018 | 04:09 PM
riverstroker04
thank you for your honest answer.
Old Apr 25, 2018 | 04:41 PM
Ford.Dude's Avatar
Ford.Dude
Alliant has a metal impeller, quite different from oem, and around 200 bucks cheaper than BPD. Bullet proof diesel's are are identical to the plastic oem only metal.
Old Apr 25, 2018 | 04:47 PM
AGE mechanic
Dieselsite has one as well.
Old Apr 25, 2018 | 04:48 PM
bismic's Avatar
bismic
There are several factors in water pumps that are important, but you can't really evaluate them -
pumping capacity (gpm and discharge pressure)
impellor balance
bearing quality and longevity
IMO a plastic impellor isn't a bad idea really, it's just that you need the right kind of plastic and it needs to attach securely (which the early pumps did not). Not sure how an individual can evaluate that though. I do know that the aluminum impellor in the BPD pump holds up VERY well. I also trust them to use quality components.
Old Apr 25, 2018 | 05:59 PM
TooManyToys.'s Avatar
TooManyToys.
Almost two decades ago there was an interesting discussion between two engineers well versed in water pump design, I think on TDS. Reading the nuances about cavitation around impeller design and seals in the bearings pretty well sold me on getting OE pumps unless it was certain any aftermarket company back engineered the design exactly. But that's just me.
Airtex used to be the company that manufactured the 7.3L water pumps, not a clue who did the 6.0L. As Mark stated, if you do plastic well it will not be a problem. But that's why there are suffix part number changes on OE parts. It's a maturing process until the part is no longer going o the assembly line.
Old Apr 26, 2018 | 06:40 AM
jsm180's Avatar
jsm180
My original pump was working fine when I replaced it @ 160k miles, I put a Motorcraft back in. I'm sure BPD makes a good product but I don't see anything that makes it better than oem.
