Holley Carb Trouble
Old Sep 18, 2003 | 03:04 PM
speedkingf100's Avatar
speedkingf100
Holley Carb Trouble
I have a 650 cfm holley carb on my 1984 351 w, and now it is having serious problems, when i stomp on the gas pedal the truck seems to cut out and it has lost power.
Steve
Old Sep 18, 2003 | 09:19 PM
71swissaqua's Avatar
71swissaqua
Holley Carb Trouble
Sounds like the accelerator pump is bad. With the engine off look down the carb and pump the throttle and see if you see 2 steady strams of gas shoot out
Clint
Old Sep 18, 2003 | 09:27 PM
speedkingf100
Holley Carb Trouble
Yes my accelerator pump works, could it be flooding itself?
Old Sep 19, 2003 | 05:29 AM
macguyver's Avatar
macguyver
Holley Carb Trouble
If the choke is closing up it could be flooding. If the electric choke heater (I'm assuming) has gone south, the only thing holding the choke open would be the choke pull-off. Then, when you open the throttle and the vacuum drops off, the choke will close.
Or, maybe the fuel filter is partially plugged and can't supply enough fuel for the demand when you get after it.
Another possibility is slow ignition (or cam) timing.
Old Sep 19, 2003 | 03:09 PM
speedkingf100
Holley Carb Trouble
Thanx for the help I have fixed the problem it was indeed the ignition timing, it wasn't advanced enough. but now my carb hesitates when i punch the gas off the line
Steve
Old Sep 20, 2003 | 02:44 AM
90f150moneypit's Avatar
90f150moneypit
Holley Carb Trouble
Check your float levels and idle speed mixtures. The idle speed mixture (screws on either side of front bowl) is the most common tip-in problems.
Stubby01
Apr 23, 2008 07:19 PM
flathead
Mar 7, 2005 05:46 PM
Steve
Sep 22, 1999 08:30 PM
