Dash Camera Install
Old Apr 23, 2018 | 09:29 PM
Raptor34's Avatar
Raptor34
Dash Camera Install
I installed a Rexing dash camera in my 2015 F-350 today. The system ties into with a fuse tap into the interior fuse box. I originally was wanting to tie into fuse 23 as it is a spare circuit. When I tied into the curcuit it seems to have power all the time. Is there a fuse that only gives power when the ignition is on, and if so which fuse is it? I also tested with the climate control circuit and ignition circuit, but they seem to be powered with the ignition off as well.
Old Apr 23, 2018 | 09:54 PM
ford390gashog's Avatar
ford390gashog
Do you have a sunroof? Easiest is to tap the wire above the overhead bin.
Old Apr 24, 2018 | 05:46 AM
Raptor34's Avatar
Raptor34
Yes I do have the sunroof. I’ll try that and let you know if it works.
Old Apr 24, 2018 | 06:41 AM
Deuce40s's Avatar
Deuce40s
If you don't mind, post some pictures of your install and review of the camera when you finish. It's hard to find honest reviews on stuff like this.
Old Apr 24, 2018 | 07:09 AM
Raptor34's Avatar
Raptor34
the sunroof is a 20amp fuse, I ended up going into fuse 44, which is the auxiliary switch fuse. I cycled the ignition and it worked as advertised. Give me a few weeks and I’ll hopefully learn all the gimmicks of the camera, but so far the only down side is the camera doesn’t show my speed, I have to view the footage on my computer to do that.
dziwei
Jul 30, 2017 04:26 PM
BMWBig6
2009 - 2014 F150
Jan 13, 2012 04:48 AM
Leader
Apr 26, 2006 12:12 AM
mike9762
Jan 21, 2005 07:31 PM
dan831wv
1983 - 2012 Ranger & B-Series
Sep 24, 2003 02:11 PM
