Cigarette lighter circuit fuse - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 09-24-2003, 02:58 PM
dan831wv dan831wv is offline
dan831wv is starting off with a positive reputation.
I have a 2000 supercab Ranger. While I was wiring a power inverter recently, the two leads touched before I could get the wire nuts on.
Of course, it tripped a fuse/breaker. I went to the fuse panel under the hood, but none of them were blown. I still don't have power to my cigarette lighter circuit.
Is there a separate fuse or circuit breaker somewhere for the cigarette lighters?
Thanks for your help!
Dan
Old 09-24-2003, 03:00 PM
stepman stepman is offline
stepman is starting off with a positive reputation.
You should have a fuse block under the dash too.
Old 09-24-2003, 03:08 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
Look on the side of the dash when you have the door open.
Old 09-24-2003, 03:11 PM
Thanks for the quick reply! The fuse is replaced now.
Tags
cigarette, fuse, lighter, series, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
