Truck Stalling out when driving
Old Apr 23, 2018 | 01:18 PM
RussellF's Avatar
RussellF
I was driving to work this morning and my truck went dead while going 30ish mph. I tried to start it, but it would just turn over and not run. I sat for around 20 minutes or so and the thing started right up like there was never a problem. There was no warning or anything and it was not running rough prior to stalling out......strange. I was pulling a 6'x12' trailer so it was a little scary loosing the power brakes. I decided to just turn around and bring the truck back to the house since it was running once again. Any thoughts on this? Thanks for any and all replies.
Old Apr 24, 2018 | 08:21 AM
lpzd's Avatar
lpzd
Hot stall , restart after cooling sounds alot like IRP solenoid .
Old Apr 24, 2018 | 09:09 AM
brian42's Avatar
brian42
Veteran: Navy
Also could be the Cam Position Sensor (CPS). I've had a couple go bad on me. The truck is running fine then the engine stalls for no reason and the Service Engine Soon light comes on. Turn the truck off and wait a minute or so and the truck starts up fine and runs like nothing was ever wrong and there's no Service Engine Soon light on.
Old Apr 24, 2018 | 10:22 AM
Walleye Hunter's Avatar
Walleye Hunter
I'd look at the IPR, they do that when they go bad. Check to see that the tinnerman nut is still on it and cool it with water or spray air next time and see if it clears right up, if it does you have a bad IPR solenoid.
Old Apr 25, 2018 | 12:35 PM
F250_'s Avatar
F250_
The CPS does the exact same thing and is a quick & easy & cheap change-out.
Old Apr 25, 2018 | 09:51 PM
pirschwagon's Avatar
pirschwagon
Quckest way to rule out IPR is douce it with cold water / ice when it does it. If it starts immediately thereafter, it's most likely the IPR.
Old Apr 25, 2018 | 09:53 PM
pirschwagon
If the Tach moves while cranking, the CMK is good. If you have a guageset installed that monitors that particular PID, even better.
FordPowerStroke
Apr 23, 2014 09:14 PM
kx450frider617
Apr 11, 2010 08:55 PM
weekendwarriorfsw32
Mar 30, 2009 02:29 AM
nodrog
Oct 9, 2008 04:52 PM
01 PSD
13
Jun 8, 2004 09:52 PM
