Rough On Start Up
Old Oct 9, 2008 | 09:01 AM
nodrog's Avatar
nodrog
Rough On Start Up
I started my 95 F250 up yesterday and it started just fine. After a few seconds though it started running real rough,thought it was going to stall right out, it stayed like this for about a minute, and then like someone fliped a switch it started running normal again. I thought it could have been a little water in the fuel or something but the water in fuel light never came on, only the check engine light came on while it ran rough and then went out when it started running normal again. I would not have worried to much about it but the very next time I stated it up it did the same thing. The way it does this make me wonder if there is a timer in the start up process and during the start up time it is doing something that is causing this. Any ideas?
Old Oct 9, 2008 | 09:14 AM
Neal 97 250's Avatar
Neal 97 250
Could possibly be the CPS. Has it died on you lately?
Old Oct 9, 2008 | 09:25 AM
wmiller's Avatar
wmiller
what about getting a little air in the system?
Old Oct 9, 2008 | 10:34 AM
Action4478's Avatar
Action4478
Get the code read ,, my WAG .... UVCH .....also ..look at the ICP sensor ,,see if oil is leaking from it...
Old Oct 9, 2008 | 11:56 AM
nodrog's Avatar
nodrog
Well I found a small fuel leak from the bottom of the fuel pump. That would explain my poor fuel milage. Going to replace the pump today and hope that works. Just seems like it would always run bad if this were the cause, but it ran great after a minute or so.
I changed the CPS a year or so ago. I think it is still good. It has not died just runs rough like it is not running on all 8.
Whats the ICP sensor?
Old Oct 9, 2008 | 12:17 PM
Action4478's Avatar
Action4478
THanks to TJ for the Pic...
Old Oct 9, 2008 | 04:52 PM
willbd's Avatar
willbd
wiring under the valve cover
Check the wiring under the valve cover. Mine 95 did the same thing and it was burnt wires.
Look at the photo onmy blog. Willbd: Powerstroke valve cover wiring issue
KLONDON
16
Oct 5, 2016 04:15 PM
rpayne99
May 23, 2016 09:17 PM
varminthunter243
22
Sep 7, 2014 12:09 PM
CatchersDad97
57
Jun 7, 2013 03:17 PM
Jnas860
Oct 28, 2011 08:36 PM
