My injector lines are leaking a little where the line goes through the nut. Is there a seal or something inside the nut? If so what are they called and where do I get them?
There is no seal, the seal is on the taper of the line to the injector or pump. You can try loosening and tightening while wiggling the line. If a try or two of that does not fix it you either have some junk between the injector and hard line in the flare/taper or the line is cracked. If you do not have vibration dampener clamps on all the lines, the line will crack and they tend to crack right under the nut before the flare.
