injector line leaking
Old Jun 28, 2007 | 01:51 PM
sampatton's Avatar
sampatton
hi one of the injector lines that connects to the injector pump is leaking. i can see it cleary coming out of the connection. are there o-rings in there that i can replace to stop the leaking. the line is tight and all. is there a way i can fix this quick cause i need the truck. thanks
Old Jun 28, 2007 | 02:12 PM
David85's Avatar
David85
Its a metal on metal tappered fitting type connection. You may have a cracked line, I would romeve the line and carefullly inspect it for damage under a good light.
These guys carry replacement lines if it comes to that:
http://www.mwfi.com/dieselPage/nav_69.htm
Or you may be lucky enough to find on at a wrecker.
Old Jun 29, 2007 | 01:53 PM
cgrandahl64's Avatar
cgrandahl64
had the same thing going on with my rig. Replaced the line, works fine. bought mine from mwfi.com. Service there was sweet and pricing was also great.
