ICP readings
Old Apr 18, 2018 | 08:03 PM
Gmcbuffalo's Avatar
Gmcbuffalo
ICP readings
I have an Edge CTS monitor and I see that it can monitor ICP pressure and ICP voltage. Is there and reason to do this and what is telling you?
Old Apr 18, 2018 | 08:07 PM
David7.3's Avatar
David7.3
Injector control pressure is a good diag tool. Lets you know how the HPOP is doing and The IPR is doing it's job. The higher the pressure the better the injectors open!
Old Apr 18, 2018 | 08:10 PM
navistarnut's Avatar
navistarnut
ICP is a measure of the high pressure oil system, and is a good tool for keeping an eye on the health of your HPO side of things.
Most folks use ICP pressure, some volts, but it's personal preference.
For instance, if you were telling the forum you are only making 3000 psi at WOT, it would indicate you likely have a leak somewhere since it's capable of closer to and even over 4000 psi at WOT.
Assuming you are running a 6.0?
R1racer
Feb 28, 2017 07:05 AM
dchamberlain
Feb 12, 2016 05:08 PM
oldbird1965
Feb 17, 2006 10:40 PM
snubber
13
Dec 2, 2004 07:38 AM
