Wiper Motor Install
Old Apr 8, 2018 | 10:45 PM
mtford's Avatar
mtford
Wiper Motor Install
Wondering if someone who has replaced their wiper motor previously can let me know if the dash gauge cluster assembly needs to be pulled to replace or if it can be done from under dash? Thanks.
Old Apr 9, 2018 | 07:30 AM
mikeo0o0o0's Avatar
mikeo0o0o0
It's done from under the dash but you need to be a contortionist.
The hardest part is removing/installing the clip that holds the linkage to the arm on the wiper motor.
Also, note the position of the arm on the motor. It can go on two different ways. If you get it 180° out, when you turn the wipers "off", they will park in the vertical position. You don't want to have to do the job twice.
Old Apr 9, 2018 | 08:12 AM
mtford's Avatar
mtford
Thanks mike!
Old Apr 9, 2018 | 09:43 AM
VitaminC's Avatar
VitaminC
Done this. PITA. It’s easier if you remove the trim and the gauge cluster, but can be done from underneath.
Old Apr 9, 2018 | 12:33 PM
meangreen92's Avatar
meangreen92
You can also remove your wiper arms, and then unbolt the 'stub shaft' assemblies from the firewall, along with the motor, and then have better access for connecting the transmission linkages to the new motor.
And take plenty of pictures of what you've got before you disassemble anything.
Here's a reference picture I took of mine when I did my cab swap:
The picture worked for me, because only after I got it all back into the new cab, did I notice that the transmission arms are marked "Left" and "Right." And it all worked the first time. I was lucky and already had the dash out for this...
stormy750
May 10, 2022 05:08 PM
52 USCG Panel
71
Sep 1, 2020 07:24 PM
oldracerjones
13
Nov 16, 2019 01:47 PM
Markhlewis
Oct 7, 2018 02:08 PM
Barney58F100
Jan 7, 2016 06:56 PM
