Sync 3 APIM numbers
Old Apr 8, 2018 | 03:13 AM
Just Strokin's Avatar
Just Strokin
Sync 3 APIM numbers
Here is a list of APIM's I was able to find on eBay and their associated numbers. Based on what the seller said as to NAV or non-NAV, I compiled this list.
You will also need to verify/update the APIM to your vehicle equipment that is controlled by the APIM. This can be accomplished with FORScan and a Windows computer/laptop along with an OBDII adapter (USB/bluetooth)
There are other parts needed to do this update such as the Sync Screen, screens to attach screen to APIM, GPS antenna and the blue cable to connect the APIM to the screen are some of known parts needed
USE IT AS YOU RISK!! I DO NOT ASSUME RESPONSIBILITY AS TO THE ACCURACY NOR TELLING YOU THE LIST IS 100% CORRECT.
I would suggest you try to obtain the VIN for the part and use the Ford AsBuilt date to determine if NAV or not.
Line 7D0-02-02 *2** > the 2 indicates NAV. View Attached video..
I would also suggest inquiring as to a 30 day return policy should the unit be deffective or non-NAV.
Here is the list I have compiled
Non-NAV
14G370-BL
14G370-JL
14G370-FBD >>>>>> back side 14G371-BF
14G370-FCB
14G370-GBD >>>>>> back side 14G371-BAG
14G370-KBA >>>>>> back side 14G371-BF
NAV
14G370-CM >>>>>> back side 14G371-CF
14G370-BM >>>>>>Ford AB > 7D0-02-02 0200 >>>>>> VIN 1FMCU9G92GUC83705
14G370-FCD >>>>>> back side 14G371-CF
14G370-KCA >>>>>> back side 14G371-CF
14G370-GCD
14G370-K >>>>>>>>***** unit located in Ukraine
14G370-FFD >>>>>>***** Unit located in UK/England
14G371-GCA
14G371-CFC
14G371-CFD
14G371-CA
14G371-DF
14G371-BF
Unknown - probably non-NAV
14G371-FC
14G370-KL
cesarp35
19
Dec 3, 2021 08:08 PM
haven56
Oct 25, 2018 09:57 AM
Jolly Roger Joe
Nov 7, 2016 10:35 PM
Randy1944
Oct 16, 2015 11:44 PM
brit_wheels_fan
Sep 30, 2014 09:10 PM
