pressure test cooling system
Old Apr 7, 2018 | 08:31 PM
jmuenchow's Avatar
jmuenchow
so over the past couple of months ive lost 2 gallons of coolant. no visible leaks that i can see and no smelly coolant white puffy exhaust smoke. does smoke clear/white under acceleration but i think that may be because i have a bad CDR valve(?). during the day there is NO white smoke under acceleration but i can see it in the night time because of the headlights of the cars behind me. anyways
i pressure tested the cooling system to about 15 psi and exposed two leaks around my upper radiator hose and line from block to coolant filter. corrected those and then decided to make sure that the pressure holds. i put it at 13 psi and no more visible leaks. the gauge would SLOWLY lose pressure. It would lose about 1/2 pound psi in about 5-7 minutes. should i be concerned or am i over reacting? could those two small hose leaks have caused me to lose that coolant over such a long period of time? i can never get any coolant to stay in my reservoir as it would always seem to "disappear". i am going to drive it now for a week or so and see if i fixed it. i am just wondering if me losing that pressure slowly is a problem or not. thanks
Old Apr 7, 2018 | 10:35 PM
DrCharles's Avatar
DrCharles
That pressure should not be dropping. You've still got a leak somewhere... if it's a small head gasket or head crack, your exhaust may not smell particularly sweet especially with the diesel aroma.
See if anything's dripping off the back of your engine down onto the Y-pipe. Could also be a freeze plug especially the ones you can't see well (DAMHIK).
Have you checked out the heater core?
Old Apr 8, 2018 | 03:11 AM
jmuenchow's Avatar
jmuenchow
heater core doesn’t appear to me leaking at all. I will test in the morning on a cold engine. And inspect everything. I suspect it may be the water pump but it was greasy around it (oil and maybe antifreeze) but I couldn’t narrow it down to just oil. Since it’ll be clean I’ll be able to tell.
Old Apr 8, 2018 | 07:47 AM
tjc transport's Avatar
tjc transport
i ain't rite
my radiator leaks at the top tank. did it with the original, and also does it with the new one.
same deal, overflow tank is always empty, so i don't use it. radiator if filled will slowly leak to 1 inch below the cap then stop and stay there. so i just leave it at the one inch below the top mark and call it good for the past 400,000 miles.
Old Apr 8, 2018 | 08:43 AM
jmuenchow's Avatar
jmuenchow
I forgot to mention. I’m fairly confident it is an external leak because when I shut down a hot engine it smells like antifreeze burning off or something. Just where is the real kicker
Old Apr 8, 2018 | 08:45 AM
jmuenchow's Avatar
jmuenchow
somewhere in the back of my head I kept saying “eh it’s alright the overflow is empty. Tom hasn’t been using one for years.” Then I poured almost 2 gallons in the radiator. Lol
Old Apr 8, 2018 | 08:52 AM
tjc transport
i ain't rite
yea, two gallons is a little more than a minor leak. ...unless you are like me and only add it once every two-three years.
Old Apr 8, 2018 | 09:55 AM
jmuenchow's Avatar
jmuenchow
it appears to be an external head gasket leak on the passenger side
Old Apr 8, 2018 | 11:22 AM
Macrobb's Avatar
Macrobb
If it's like what mine did, it'll probably only leak under heavy load, or leak very very little.
Keep an eye on the oil filter when you remove it - If you see "clean spots" on the metal where oil kind of...pushes away, it's minor amounts of coolant leaking internally too.
I've seen that on two IDI engines with minor head gasket leaks.
In the case of my '93, I had a year from when I started seeing trails on the outside of the head gasket until it catastrophically blew, with constant bubbles in the overflow and 'steam cloud' out the exhaust.
Old Apr 8, 2018 | 11:40 AM
jmuenchow's Avatar
jmuenchow
It looks like it could be trailing from the thermostat housing. Just degreased the engine and going to retest to verify.
Old Apr 9, 2018 | 02:13 PM
jmuenchow's Avatar
jmuenchow
Ok gents. Sorry it was a late night last night and didn’t get to respond. The verdict was that the top tank on the radiator was leaking along with the top radiator hose at the thermostat housing. That was trailing down to where the block and head meet (towards front of the engine). I degreased and pressure washed the crap out of the engine. Tightened up and adjusted the hose clamp as it was pretty far from the edge of the hose. And retested. Since the radiator hose was fixed all the pressure that was escaping (and leaking) from top radiator hose was forced only to the radiator. It was bubbling and leaking like a son of a gun. Replaced the radiator and re pressure tested the cooling system and all (seems) to be well. I hope this fixed me problem. I will report back over time with whether it did or did not.
Old Apr 12, 2018 | 06:13 PM
jmuenchow's Avatar
jmuenchow
Ok so it’s now been 3 days and I have lost ZERO coolant. By now I would’ve lost a little bit out of the overflow tank but it has held true. I’m glad this fixed it.
rockin300
Apr 17, 2013 03:03 PM
mancamp74
Jun 25, 2007 01:13 PM
FLgargoyle
Sep 28, 2006 06:57 PM
F-150_XL
Nov 28, 2005 10:40 PM
dorsetmerv
Oct 6, 2005 12:56 AM
