causes for knock, not injectors
Old Apr 24, 2014 | 05:43 PM
Red454sedgwick's Avatar
Red454sedgwick
I just got done putting in injectors and the truck still knocks, has anybody ran into any thing else.
Anything to check into before I pull the engine.
7.3 f250 cc auto 2002
Old Apr 24, 2014 | 07:15 PM
F350-6's Avatar
F350-6
Fuel pressure.
Low pressure will cause a knock. Really low fuel pressure causes a knock that sounds internal.
Old Apr 24, 2014 | 08:02 PM
timmyboy76's Avatar
timmyboy76
air. Air in oil
Old Apr 24, 2014 | 08:05 PM
Bonanza35's Avatar
Bonanza35
Fuel pressure is really important. So check it at idle and on the road under power! I would think if its internal with the oil cap up it would smoke badly out the filler hole.
Old Apr 24, 2014 | 09:22 PM
Red454sedgwick
I like the low fuel pressure Idea, how would you check for air in oil and what would fix that.
These need 50 psi of supply pressure right?
Old Apr 24, 2014 | 11:54 PM
Red454sedgwick
where's the test port for fuel pressure?
Old Apr 25, 2014 | 12:29 AM
ebbnflow's Avatar
ebbnflow
On the back of the fuel bowl. The upper left is pre filter. The lower right is post filter. I believe you need a 3/8" Allen to get them out.
Old Apr 25, 2014 | 01:17 AM
clem1226's Avatar
clem1226
Air in fuel as well, ford called it "cackle" but it always sounded like a knock to me. Have you done any of the in tank mods or a regulated return? When you replace all the injectors did you install all ADs or did you put an long lead injector in #8?
Old Apr 25, 2014 | 04:44 AM
JockD's Avatar
JockD
Take it out and drive it at 50-60 mph, then take your foot off the accelerator pedal. If the knock stops, it is injector-related, since the injectors quit firing in this situation.
I have an injector knock in #7 (passenger side rear cylinder) that remains despite replacing injectors, UVCH, high-pressure oil cross-connect, regulated fuel return, in-tank mods, careful inspection of all wiring harnesses, substituting a known good IDM and PCM, changing the CPS, and trying various fuel additives for injector lubrication. Fuel pressure and HPOP pressures are great. I have a clear filter housing just before the electric pump and see no air coming from the tank.
Sometimes there just isn't a solution.
Old Apr 25, 2014 | 11:16 AM
Red454sedgwick
ads with the special no. 8
Old Apr 25, 2014 | 11:18 AM
Red454sedgwick
no other mods, I should look at the screen in the tank too
Old Apr 25, 2014 | 12:11 PM
Tugly's Avatar
Tugly
How many miles since the injector swap?
Old Apr 25, 2014 | 01:00 PM
Christof13T's Avatar
Christof13T
Oil can be tested for air (foaming) with a fairly straight forward procedure.
With the engine at operating temp...
Hook up to the trusty obd port with s9mething that can see icp.
Rev up to 3k rpm.
Watch icp.
Hold 3k rmp for 2 full minutes.
If your pressure drops at all while holding throttle... you have air.
Symptom can point to hpop going south.
If the test runs good... start thinking about mechanical issues like foreign object, or piston slap, or play at the rod journals. I strongly recommend you compression test if you have not done so already.
Old Apr 25, 2014 | 03:45 PM
Red454sedgwick
5 miles
it's quits every once in a while, but now I think the o-rings are out of the oil cooler it's putting water into the oil
Old Apr 25, 2014 | 04:36 PM
Christof13T
Run it hard for a good 50-75 miles.
Takes at least that to work all the air out after having the system open.
