2015 + Expedition & Navigator 2015 + Ford Expedition and Lincoln Navigator
Quick response please.
Old Apr 5, 2018 | 04:47 PM
mxer0022's Avatar
mxer0022
I'm currently on a test drive in a 2016 limited and it doesn't have Navigation. Can this be enabled via Forscan or would the dealer have to enable it?
Old Apr 6, 2018 | 06:50 AM
FreeWill's Avatar
FreeWill
You can add it with Forescan. Not sure if you need any hardware or not. I use my Android for navigation. It's better, and you can actually watch it on your truck display if you want (I use a windshield mount).
I was a bit worried that my former rental didn't come with navigation. Completely unnecessary for me so I have never even tried to enable it.
Old Apr 6, 2018 | 07:23 AM
mxer0022's Avatar
mxer0022
So I don't need to get a new sync module? I have Forscan that I have been using on my 15 superduty so if I can do it with forscan that would be bitchn.
Old Apr 6, 2018 | 10:17 AM
B-McD's Avatar
B-McD
So if the truck doesn't have Nav, do our trucks with Nav have a DVD/hard drive somewhere like many other cars. Plus the GPS antenna? But I have used Android Auto to put the Waze map up on the screen. I don't use AA much as it takes over my phone while in use.
Old Apr 6, 2018 | 01:41 PM
mxer0022's Avatar
mxer0022
From what I found the nav and maps are loaded onto the sync module that is mounted to the back of the screen. I watched a video of a guy who sells the modules and he said you didn't need to add a GPS antenna. All he did was change out the module. But if you can use Forscan to enable nav then you can do it for the cost of a bluetooth obdII adapter which is about $80. The cost of a new sync module from what I found is roughly $1,300.
Old Apr 6, 2018 | 02:16 PM
ad2435's Avatar
ad2435
I don't like or use the nav in my 15 expy plat. It is a pain to enter and address and there has been a few times that it was completely incorrect.
I can tell my phone, "ok google navigate to 123 main street, anytown" and navigation has started.
To do the above with sync nav, you have to say so many things over and over and over....
I do use the nav for simple map functionality like if i need to see what street I am coming up on but that is about it.
Old Apr 8, 2018 | 09:54 PM
SoylentSaxgod's Avatar
SoylentSaxgod
cannot be enabled. Can be added by replacing APIM.
Old Apr 8, 2018 | 10:47 PM
johnkn's Avatar
johnkn
Does mine differ from yours?
i push the button on the steering wheel and say "destination", then respond "street address", then speak the address, then answer "set as destination".
ACADguy
2015 - 2020 F150
19
Jul 20, 2017 07:48 AM
Bristol Blue
Apr 12, 2017 07:57 PM
HIGHRAILER
2009 - 2014 F150
Jan 9, 2012 09:54 AM
INFLUENCER
2004 - 2008 F150
31
Mar 18, 2007 05:02 PM
BIG-BAD-794X4
General Automotive Discussion
Jan 19, 2006 12:32 PM
