no throttle up
Old Dec 28, 2010 | 02:53 PM
armstrongfordtrucks's Avatar
armstrongfordtrucks
Question no throttle up
After having the problem of no cold start, fixed that, starts outside at 14*, romps for a little bit, 10 to 15 seconds, but smooths out quickly, will not throttle up at start, I mean I can't just drive away for a minute or two. This is the same in stock and 80 econo.
Should I remove the tuner to see if it goes away or look for something else ? I never drove this truck in the cold before this year. Purchased it over the summer from Texas.
Thanks for all the help in advance.
armstrong
Old Dec 28, 2010 | 03:47 PM
Automator's Avatar
Automator
What do you mean by not throttling up at start? When very cold my truck is very sluggish but will still move and I think that is more along the lines of the EBPV valve warming the engine.
Old Dec 28, 2010 | 03:54 PM
Lloydable's Avatar
Lloydable
I When your trying to drive it, roll down the window and listen to the exhaust. If it makes a really loud wooshing sound, you ebpv is closed trying to warm up.
Also from what i understand oil provides the fuel. So when the oil is cold, it at least doesn't feel like its getting the fuel.
Mine is usually very slow and hesitant if i just start it and drive away, but if i let it idle to half op temp, it is no where near as bad.
Old Dec 28, 2010 | 04:12 PM
rbaker6336's Avatar
rbaker6336
Might be the ICP sensor,when mine started going bad truck would only idle with throttle wide open.Then after a little while would run normal
Old Dec 28, 2010 | 04:21 PM
carltonwebb's Avatar
carltonwebb
I have seen some of the trucks when cold not want to throttle when cold. After a few minutes warming up, they would throttle up and run fine. Is your oil really thick? You might consider changing it to the synthetic 5w40 to see if that will help. I imagine its been cold there this time of year.
Old Dec 28, 2010 | 04:29 PM
armstrongfordtrucks
Well, i guess after thinking about it the truck is usually in the garage . I will leave it out tonite and see if it is just slow but does move .
Thanks
Armstrong
Old Dec 29, 2010 | 02:26 PM
dmm50's Avatar
dmm50
throttling up issues
FYI I just replaced my EBPS tube and the problem went away, It was rotted off in the middle of the tube,go to www.guzzle7pt3.com/ebps.php. this tube and sensor is what sends info to the ebsv on the turbo to open and close, if it is clogged or rotten the ebpv is open and closed when it should not be causing throttling/whinning problems. at the very bottom of the turbo there is the ebpv,when cold have someone start the truck and watch the ebpv, it should turn olot at start, if it does not turn alot this is your problem. i just went through it
tcjhkbjt
Nov 14, 2014 07:13 AM
arkredneck
16
Dec 5, 2013 01:51 PM
mdula
Jan 11, 2011 12:27 PM
texas zeke
Modular V8 (4.6L, 5.4L)
Aug 31, 2008 11:27 PM
