2009 towing empty?
Old Apr 2, 2018 | 07:26 PM
thunderbolt427's Avatar
thunderbolt427
2009 towing empty?
I have a 09 F150, 5.4. I was towing my car trailer today in overdrive. Trailer empty, 18'. Should I have put it in tow mode for an empty trailer? It towed fine, no excessive down shifting. Also, I will be moving a 1000 lb lawn tractor, same question. Thanks
Old Apr 3, 2018 | 07:13 AM
Robbgt's Avatar
Robbgt
I wouldn't worry about it, unless the transmission is hunting around for the right gear. Same with the lawn mower. Tow mode will hold the gears a bit longer and give you some engine braking when stopping. Give it a try next time to see what you think.
Old Apr 3, 2018 | 07:54 AM
rbentnail's Avatar
rbentnail
If it "tows fine [with] no excessive down shifting", regardless of what/how heavy it is, I don't worry about it. Moderate loads in the mtns require tow mode whereas the exact same load at the coast does not. I just play always it by ear.
Old Apr 15, 2018 | 08:31 AM
thunderbolt427
Thanks for the replies.
Old Apr 15, 2018 | 08:36 AM
David7.3's Avatar
David7.3
I always tow in OD, you will get the feel as you experiment with your driving style, tow/haul increases line pressure in the trans and holds the gears abit longer and also doesnt allow TC lockup the same so mileage will hurt. Just do what the truck is telling ya but you wont hurt the trans, if the fluid gets hot you will know.
Old Apr 15, 2018 | 01:48 PM
seventyseven250's Avatar
seventyseven250
I like the transmission behaviour in tow mode
danocross
All Things Towing
31
Aug 29, 2013 11:33 AM
adbscu
Sep 6, 2009 07:40 AM
rjdpowerstroke
May 20, 2009 05:42 PM
FourbynFord
Aug 17, 2008 06:12 AM
m_disco
Aug 13, 2003 11:28 AM
