Trailer Towing Question
Old Aug 12, 2003 | 08:26 AM
m_disco's Avatar
m_disco
Question Trailer Towing Question
I've read in various places that your not supposed to use overdrive when towing a trailer.
Would this matter if the trailer i'm towing doesn't weigh much?
The reason I'm asking is that I have a canoe trailer that when loaded with two canoes weighs in less than 500lbs. Maybe around 300lbs.
Whenever I tow our camper the o/d is always off, but I'm wondering if with this lighter trailer, I would be able to use the O/D and get better gas mileage without doing any damage to my truck.
Thanks
___________
'99 XLT 4.0L SOCH - 5spd Auto
Old Aug 12, 2003 | 09:27 AM
CobraXP's Avatar
CobraXP
I doubt you would have any problems with only 500lbs behind you. When people talk about running in Drive and not Overdrive when towing, they are talking about heavier loads such as large boats, car trailers, etc. I run my X in Overdrive when towing my 2 jet skis when I am on basically flat roads...
Old Aug 12, 2003 | 12:22 PM
stubborn1's Avatar
stubborn1
I tow my popup camper in OD when I am on flat surfaces. You just need to use your best judgement and downshift to drive before the transmission starts to get bogged down. After towing a few times, its pretty easy to anticipate when you need to downshift going up a hill.
Also, I always start out in drive when merging on a freeway, highway, etc. until I get close to my cruising speed. The transmission likes to shift to OD rather quickly otherwise.
Old Aug 13, 2003 | 11:28 AM
m_disco's Avatar
m_disco
Thanks, that's what I thought but I just wanted to confirm it before I went and did something to my truck.
