No crank
Old Apr 1, 2018 | 11:12 PM
Brian Lowther's Avatar
Brian Lowther
No crank
I have a 1996 150 that wont crank or click and cant figure out the problem all help is needed
Old Apr 2, 2018 | 12:16 AM
Tedster9's Avatar
Tedster9
Welcome to FTE Brian
OK since we don't know your experience level - or what you've done so far to eliminate possibilities - you have to check that battery is serviceable. When a battery gets old or reaches the end of its useful life it can still measure 12+ volts, dash lights work, radio, etc, but is unable to supply enough current under the load of starting the engine. How old is the battery? Has it run down lately? Have you tried charging it?
Lots of things to do at this initial stage, they mostly revolve around making sure battery is good, and charged, cables and connections are clean and tight.
Measure voltage while cranking is a good test. Also, check to see if any of the cables get hot, this is a sure sign a connection is loose. Simple things like that.
Do the headlights work? Nice and bright? What happens to the headlights, if you try to crank the engine over? Just take it one piece at a time and you'll get it figured out.
Old Apr 2, 2018 | 01:29 AM
88n94's Avatar
88n94
Take something metal and bridge the two large posts on the fender mounted solenoid. That will tell you if the starting system is operational. Make sure the transmission is in park, or neutral if you have a manual transmission.
Old Apr 2, 2018 | 07:45 AM
Brian Lowther
No crank
So it's a brand new battery I have power going to everything in the cab of the truck radio plays hear the fuel pump kick On. exterior lights when they are on do not dim when I turn the key. I go turn the key and I get absolutely nothing.
Old Apr 5, 2018 | 01:25 AM
1TonBasecamp's Avatar
1TonBasecamp
Could be several things still, but a common issue is the neutral safety switch or connector. Is this an automatic transmission, or manual?
Someone else will have to give the details, since I don't know exactly where your connector is, or if it's one of the simpler 4 to 6 wire models, or one with 783 wires on it! As a '96, I suspect the latter.
Ok, so it's probably only got 8 or 10 wires, but it's not the old simple 4-wire switch with only two wire colors.
But either way, it keeps the ignition switch from getting power to the starter relay under the hood when you turn the key to START
Check for loose or corroded connections at the starter relay (solenoid thingy), check for loose or corroded cables to the battery and starter, and even try jiggling the transmission shift lever around while you turn the key to see if that helps. Put it in Neutral and try again.
Of course, it could be other things as well, but that's a place to start at least.
Paul
Tranz zam
Apr 30, 2016 09:14 PM
Birdman_7137
May 7, 2013 12:30 PM
andym
Feb 1, 2010 07:42 PM
danfarrands
1983 - 2012 Ranger & B-Series
Dec 25, 2008 10:54 PM
sayles26
Apr 10, 2005 09:08 AM
