1970 (or 71?)
Old May 6, 2013 | 08:23 PM
Birdman_7137's Avatar
Birdman_7137
1970 (or 71?)
Okay so it turns out this truck has been run about a year ago, I did not know that. The tires are pretty flat, and it's in the woods enough I can't get to it with my car to try to jump it. So here's what's happening..
I turn the key to the ignition and a light to the left of the ignition comes on, but when I go to turn it over ABSOLUTELY nothing happens no click no nothing. However I can still turn the lights on, they work. I had a problem with a car I was hitting too much bass on and I burnt out the battery. The voltage was still fine at 12 volts, but it had no crank amps ( I found out). Could that be what's happening?
I popped open the distributor, the contacts look relatively clean, so I can imagine it being those...
Hopefully it just needs a new battery??
Old May 6, 2013 | 08:32 PM
HIO Silver's Avatar
HIO Silver
In your attempt to crank the engine over, clean or replace the battery cable connections and use a known good battery.
Old May 6, 2013 | 09:15 PM
crazed87bronco's Avatar
crazed87bronco
Also try replacing the starter solenoid after acouple years of my 64 not running I went to try starting it and had the same thing nothing but lights worked replaced the solenoid and it fired right up. Also clean or replace your battery connections at all ends and grounds
Old May 7, 2013 | 12:30 PM
BradyCouchman's Avatar
BradyCouchman
one way to test to see if its the solenoid is use a par of pliers and jump the two big terminals...just be ready for the sparks...did this to start my truck to get home when mine went out.
You can also use a test light to see if you get power to the solenoid when you are trying to crank, should be one of the two small terminals. if you dont have power while cranking at one of the small terminals then jump from the battery to i think the one on the left, or side the battery cable is on.
axidjw
North Carolina Chapter
Jan 6, 2017 02:06 PM
phurst
26
Nov 17, 2010 06:12 PM
F250-76
Sep 11, 2010 09:43 PM
jimsallee
May 22, 2009 08:59 AM
tealboy1
Oct 10, 2004 06:42 PM
