Rim interchangeability
Old Apr 1, 2018 | 04:07 PM
cdnfireman's Avatar
cdnfireman
I have a set of 17” rims off of a 2011 f150 and am curious if they will work okay on my brothers 2007 f150. I know the diameter is the same, just wondering if the bolt pattern and offset will be the same?
Old Apr 1, 2018 | 05:28 PM
P.Bronner's Avatar
P.Bronner
I know the pattern is the same, and I'm about 99% sure the offset is also the same.
Old Apr 2, 2018 | 01:41 PM
gDMJoe's Avatar
gDMJoe
Arrow
cdnfireman - I have a set of 17” rims off of a 2011 f150 and am curious if they will work okay on my brothers 2007 f150. I know the diameter is the same, just wondering if the bolt pattern and offset will be the same?
The rim spec's (bolt pattern, offset, center bore) are the same.
-click- the pic'
Goth 150
< This space intentionally -blank- >
Old Apr 2, 2018 | 04:28 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Wheels from 2004 through 2018 are completely interchangeable, TPMS sensors and Lug Nuts are not if they are from a 2015-up truck.
Old Apr 2, 2018 | 07:34 PM
gDMJoe's Avatar
gDMJoe
AlaskanEx - Wheels from 2004 through 2018 are completely interchangeable,
Exceptions being ...
  • 2004 Heritage model (5-bolt pattern)
  • HD payload (7-bolt pattern)
Regarding the gen' 13 (2015+) rims ... The spec's and fitment are the same, however, due to changes in the rim's lug nut seating, the gen'12 lug nuts (which must be used since the threads changed in 2015) will stick-out slightly - a minor cosmetic difference.
Also ... TPMS sensors priior to 2009 are not compatible for gen'12 (2009-2014) wheels.
-click- the pic'
Goth 150
Old Apr 2, 2018 | 09:39 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Damn I forgot about the 05?-08 trucks having TPMS the 04 new body style we had was before they had it.
Old Apr 2, 2018 | 11:30 PM
P.Bronner's Avatar
P.Bronner
Must've started in 06 or 07. The '05 doesn't have it.
Old Apr 3, 2018 | 12:18 PM
gDMJoe's Avatar
gDMJoe
P.Bronner - Must've started in 06 or 07. The '05 doesn't have it.
2008, maybe (?) very late-build 2007s. They had the band-type TPMS sensors (part # 6F2Z-1A189-A).
josh33
1978 - 1996 Big Bronco
May 12, 2009 09:19 AM
Murk
Aug 13, 2006 12:15 AM
pancake
Aug 26, 2004 09:41 AM
Reg Wal
Apr 25, 2004 08:47 AM
Reg Wal
1947 and Older Ford Trucks
Apr 23, 2004 01:34 PM
