2012 E-Locker noise when engaged on Ice???
I have just started to have this problem or what I think is a problem. When the electronic rear axle is locked and in icy conditions I am getting clunking sounds out of the rear end sometimes. Sorry its hard to explain but it sounds like it is slipping in and out of engagement. Sometimes it works fine or what I think is fine and locks both wheels together and I get no sound at all. I switched off the traction control thinking that the sounds I was hearing were a result if it kicking in but this didn't change the sounds the rear diff is making. Has anyone else had this issue?
Sorry its not a "Posi" or what others refer to as a Limited Slip rear end. It is the electronic locking differential that is now an option on the certain trucks. My truck also does not have the Auto 4wd option. I am not turning when this happens and I have just taken it into the dealer this morning and they agree that there is a problem. I just wanted to know if anyone else has experienced this.
I have read that when you turn off traction control it does not turn off the braking traction control. Like if you have it in regular 2wd and one wheel slips it puts brake to that wheel and the other spins. I personally hate the system even though I know it helps because it makes the truck jumpy. I live in alaska so we already have pretty much permanent ice on some of the less/not maintained roads. Taking off from a stop sign i can feel power switching back and forth between the back tires and it is annoying. Only way I have seen to get around it is to go over half throttle and just spin both tires fast, and that is not good for ice. Even if you hold the button for 5 sec and turn off all the stuff it still does not turn that function off.
I would not think this would be your problem since you can lock the rear in 2wd(i cant because mine is a 2011) but you never know it might be bugging out even with it locked.
Pitt4212
6.7L Power Stroke Diesel
159
04-10-2018 10:05 AM
