any ideas?
Old Mar 31, 2018 | 10:08 PM
jerryst's Avatar
jerryst
any ideas?
I have a 292 y block. I have a problem with a push rod intake number 3 cylinder. The y block dropped the push rod. So I put back the pushrod and adjusted the valve. While rotating the motor clockwise the push rod will pull away from the adjuster on the rocker. The lifter moves up and down in its bore. Also the spring and valve compress and rebound. I took out the pushrod on intake and exhaust on number 3 and compared them. The exhaust pushrod seems to stay in contact with the lifter while the intake dosnt. Both push rods seem to be straight. But when I put them side by side the intake push rod seemed to be bowed a little. The valve spring height seems to equal to the others. Also does anyone know the length of stock push rods? But the big question is why is the intake push rod doing this? I am out of ideas.
thanks
Jerry
Old Mar 31, 2018 | 10:20 PM
Mixer man's Avatar
Mixer man
Did you float the valves at some point?
Old Mar 31, 2018 | 10:28 PM
jerryst's Avatar
jerryst
No truck motor has no miles on it. I rebuilt it years ago and life and other cars got in the way. i finally got tired of walking around it and cussing at it. I got it started and the truck smoked bad. I did a compression check and found number 8 dead. So I pulled off the valve cover off and found dropped pushrods. So I took off the intake and fixed number 8 cylinder. But just have problem with number 3. The intake valve was sticking but I got it to close with marvel mystery oil. I am thinking of ordering new pushrods. What do u think?
Thanks
Jerry
Old Apr 1, 2018 | 01:06 AM
seaves46's Avatar
seaves46
Simply roll the pushrod on a flat surface , you will soon see if it's bent .
Old Apr 1, 2018 | 08:06 AM
cowdog86's Avatar
cowdog86
Bent or wrong pushrod. Get a new set all around.
Old Apr 1, 2018 | 08:20 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Here’s some info I found on the NET.
Y-BLOCK DIMENSIONS
Old Apr 1, 2018 | 08:29 AM
Mixer man's Avatar
Mixer man
I'm beginning to think #3 intake valve may have a bent stem.
Old Apr 1, 2018 | 08:53 AM
bigwin56f100's Avatar
bigwin56f100
or a rusty valve stem not allowing it to close fully
Old Apr 1, 2018 | 09:16 AM
Mixer man's Avatar
Mixer man
Yes, initially. Until it got slapped by a piston. Still speculating...........
Old Apr 1, 2018 | 09:31 AM
bigwin56f100
On a stock
y block the pistons are too far in the hole. Ive had them stick and never had contact
Old Apr 1, 2018 | 06:13 PM
jerryst's Avatar
jerryst
I am leaning towards stuck intake valve. I tried marvel mystery oil carb cleaner and pb blaster.all in small amounts still won’t unstick valve. Oh well have too end off I will take off head and have it checked out.
thanks
jerry
Old Apr 2, 2018 | 01:54 PM
jerryst's Avatar
jerryst
I just had a thought. Since it seems we are in agreement that there is rust varnish or worst a bent valve. Can I spray carb cleaner down this intake ports on the cylinder head? I would do it like three days in a row. I have tried spraying around the valve springs. What do you all think. If it doesn’t work I will take off the heads.
thanks
jerry
Old Apr 2, 2018 | 02:39 PM
Tedster9's Avatar
Tedster9
Try using Marvel's oil per directions on the can, it is designed to be used in the fuel and the oil. It really works.
If something is bent, well it's not gonna fix that. Too late. Use it before, not after. Good stuff.
Old Apr 2, 2018 | 04:19 PM
seaves46's Avatar
seaves46
Get in there with a pick or something and lift the valve stem seal if you can , then give it a spray with something .
ALBUQ F-1's Avatar
ALBUQ F-1
Since this is a fresh motor, I have to wonder if the valve guides were replaced during the rebuild, and were not reamed before the valves were installed? Pressing in the guides can distort the ID of the guide enough that reaming is necessary. Maybe the shop didn't have the correct size reamer, and skipped that step?
