How important is engine balancing
Old Mar 31, 2018 | 11:58 AM
ryan73ford's Avatar
ryan73ford
I've got a 96 50oz 302 buy my parts are from 73 so it's a 28oz harmonic balencer and flywheel, so what would happen if I through those older parts on there? Would the engine just rev too high or would I actually break something important? Any help is appreciated thanks
Old Mar 31, 2018 | 12:27 PM
1TonBasecamp's Avatar
1TonBasecamp
It would shake you out of the truck. No lie.
So performance balancing, such as you do when the engine is being machined, is very good, but not a requirement for running.
Your idea of using mismatched parts however is a complete non-starter. Don't even think about it.
Paul
Old Mar 31, 2018 | 12:31 PM
1TonBasecamp
Besides, if you're swapping in a used engine, you need to renew certain things anyway. It's just common sense so you don't have to do it later.
And what if your timing marks for the 302 balancer don't line up with the timing pointer on the engine? Or are you swapping over the old timing cover too? Ford used at least three different sets of timing marks and pointer combinations, so that's always something to be conscious of.
Even the manufacturers put the wrong parts in the boxes sometimes, because they all look the same to some people.
Oh, and back to your balance, when performance balancing we're talking down to fractions of a GRAM. The roughly 22 OUNCES of misbalance at that point would be the eventual death of the engine at some point.
If you could stand to run it that long that is.
I've seen the wrong parts used, and while it idled someone normally, but the time you were at 1200 to 1400 rpm the guy KNEW he'd made a big mistake!
Old Mar 31, 2018 | 12:36 PM
willowbilly3's Avatar
willowbilly3
I put the wrong flywheel on a 428 once and on a 302 another time. Anything off idle and they shake like a dog crapping razor blades.
Old Mar 31, 2018 | 02:01 PM
mark a.'s Avatar
mark a.
It will tear the main bearings right out of it.
Old Mar 31, 2018 | 03:09 PM
Jacob Bowman's Avatar
Jacob Bowman
might look something like this
Old Mar 31, 2018 | 03:27 PM
meangreen92's Avatar
meangreen92
Cool video!!!
85_Blue
Dec 21, 2010 10:37 AM
79whitetrash
May 9, 2010 08:53 AM
david00f150
Aug 27, 2006 11:07 AM
munrow
May 11, 2005 10:31 AM
swall
Dec 2, 2002 09:18 PM
