OBD link device
Old Mar 31, 2018 | 09:03 AM
krobbins's Avatar
krobbins
OBD link device
Just installed it and tried cranking truck and it just spun over with no crank. It finally cranked and lost bt connection and while running I pressed connect on phone app and truck stumbled but continued to run. I checked my boost and it was only 0.1 at idle and only 3 with revving engine to 2700 rpm.
Old Mar 31, 2018 | 09:34 AM
Jaime74656's Avatar
Jaime74656
What is the truck we are working with? What is the obd device you have and what brand? Is it ELM327 compliant? Would love to help but due to a lack of needed info I am unable to assist.
Old Mar 31, 2018 | 09:41 AM
krobbins's Avatar
krobbins
It's a 2000 f350 and it's a obdlink mx
Old Mar 31, 2018 | 09:56 AM
Jaime74656's Avatar
Jaime74656
What app or apps are you using? Android or Apple device?
Old Mar 31, 2018 | 10:00 AM
Tugly's Avatar
Tugly
I've seen stuff like this happen when a bogus gauge is selected on the app. It's best to test each gauge on the app with KOEO before trying to load 'em all up at once.
krobbins's Avatar
krobbins
I have the Android phone, or Google pixel and using the app for the device from playstore
Old Mar 31, 2018 | 10:01 AM
krobbins's Avatar
krobbins
What is KOEO
Old Mar 31, 2018 | 10:17 AM
Walleye Hunter's Avatar
Walleye Hunter
Originally Posted by krobbins
What is KOEO
Key On Engine Off, as opposed to KOER, which is Key On Engine Running, the one we use to monitor most of the sensors in use.
Old Mar 31, 2018 | 10:35 AM
roozterdvx's Avatar
roozterdvx
I use a Konnwei KW902 ELM327 OBD Bluetooth to connect to my laptop for Forscan
https://www.ebay.com/itm/KONNWEI-KW9...gAAOSwr6FaIPB3
Old Mar 31, 2018 | 12:39 PM
Shovelheadrob's Avatar
Shovelheadrob
You won't have boost at idle & the engine makes boost when loaded not when you just hit the skinny pedal.
Old Apr 1, 2018 | 07:32 AM
Tugly's Avatar
Tugly
You are in luck. If you search 2018 PIDs, you will find the configuration files for Torque Pro - including screens I set up on my Google Pixel2
Old Apr 1, 2018 | 07:59 AM
krobbins's Avatar
krobbins
Should I use torque pro app (free or paid), instead of using the OBDLink app from the OBD link mx device?
Old Apr 1, 2018 | 09:38 AM
Jaime74656's Avatar
Jaime74656
yes we have had the best luck with Torque pro (check the 2018 PIDs thread and the Torque Pro FAQ link in my sig for more helpful info) sounds like a PID is not playing well with the app you are trying to use...
Old Apr 2, 2018 | 07:21 AM
Tugly's Avatar
Tugly
I have tried every reasonably decent Android app that can read all the sensors on our OBDII ports - Torque Pro is the most user friendly, reliable, configurable, and attractive. The rest either look lame or are lame - for daily monitoring. FORScan wins hands-down for troubleshooting, but TP is the one I bring up for daily driving.
Old Apr 2, 2018 | 01:08 PM
brian42's Avatar
brian42
Veteran: Navy
I have had this happen a couple of times where the truck would not start. Close your app or pull the BT adapter out of your OBDII port and then your truck should start up.
