OBD link device
Just installed it and tried cranking truck and it just spun over with no crank. It finally cranked and lost bt connection and while running I pressed connect on phone app and truck stumbled but continued to run. I checked my boost and it was only 0.1 at idle and only 3 with revving engine to 2700 rpm.
What is the truck we are working with? What is the obd device you have and what brand? Is it ELM327 compliant? Would love to help but due to a lack of needed info I am unable to assist. |
It's a 2000 f350 and it's a obdlink mx
What app or apps are you using? Android or Apple device? |
I've seen stuff like this happen when a bogus gauge is selected on the app. It's best to test each gauge on the app with KOEO before trying to load 'em all up at once.
I have the Android phone, or Google pixel and using the app for the device from playstore
What is KOEO
Originally Posted by krobbins
(Post 17896663)
What is KOEO
I use a Konnwei KW902 ELM327 OBD Bluetooth to connect to my laptop for Forscan
https://www.ebay.com/itm/KONNWEI-KW9...gAAOSwr6FaIPB3 |
You won't have boost at idle & the engine makes boost when loaded not when you just hit the skinny pedal.
(Post 17896660)
You are in luck. If you search 2018 PIDs, you will find the configuration files for Torque Pro - including screens I set up on my Google Pixel2 |
Originally Posted by Tugly
(Post 17898034)
(Post 17898066)
Should I use torque pro app (free or paid), instead of using the OBDLink app from the OBD link mx device?
I have tried every reasonably decent Android app that can read all the sensors on our OBDII ports - Torque Pro is the most user friendly, reliable, configurable, and attractive. The rest either look lame or are lame - for daily monitoring. FORScan wins hands-down for troubleshooting, but TP is the one I bring up for daily driving.
https://cimg3.ibsrv.net/gimg/www.for...d65fd33814.png |
(Post 17896561)
