Aussie 250 fuel problems
Old Mar 30, 2018 | 10:59 PM
kingswood202's Avatar
kingswood202
Ok so I have a bricknose with a injected 351w and it's having some sort of problem with fuel delivery now when I turn the key to the on position the pump doesn't prime anymore but if I turn it a bit further half way between on and start it clicks and primes then when try to start it it will fire once then just crank like the fuel pump doesn't keep running is there anything I can test is the pcm bad or something it ran fine before it's been sitting for about a month now while I was doing some body work and fixing the dash trims also I had the column unbolted so I could get the dash out
Old Mar 31, 2018 | 01:55 AM
Shadow944795's Avatar
Shadow944795
Check for pressure at rail and spark from coil then from dizzy to plug. Confirm all that functions. Two pins can be jumper-ed to wire on the fuel pump to stay running for testing in case its not keeping it primed up like it needs. If no start and you got both then take a test light and unplug an injector connector, and see if you get a pulse while cranking the engine from the light, thats a dirty way to see if the PCM is doing its job but it could easily mean a bad pip or TFI. Hard to guess thoose without more tests. Start with the basics, report back with findings.
Old Mar 31, 2018 | 01:43 PM
subford's Avatar
subford
Bad Ignition Switch.
Your Power relay is not closing with the on position or in start position.
Old Apr 1, 2018 | 11:24 PM
kingswood202
yeh seems to be the ignition if i hold it in between it keeps running stange when it was working fine before
Dstosh
Jan 14, 2022 01:29 PM
Lloyd62
2004 - 2008 F150
Jul 27, 2017 08:47 AM
dalekatz13
38
Jan 24, 2013 09:50 AM
black95tt
17
Oct 2, 2007 12:10 PM
tampabandit
Nov 8, 2004 10:49 PM
