Fuel or electrical
Old Jul 26, 2017 | 02:59 PM
Lloyd62's Avatar
Lloyd62
Fuel or electrical
My 04 f150 died on me after a long trip. It sat a few hours and started again. Tried the next day......nothing! I changed rail sensor, drive module AND fuel pump! Still wont start without a squirt of ether! Soooo what do I do next???? Help please
Old Jul 26, 2017 | 03:05 PM
alloro's Avatar
alloro
When it doesn't start does the fuel pump get power. There have been issues with the fuel pump relay going bad.
Old Jul 26, 2017 | 04:12 PM
steve(ill)'s Avatar
steve(ill)
by drive module, I assume you mean the Fuel Pressure Module. ..... good check as alloro said is turn the key "ON", but not to start....... have someone listen to see that the fuel pump starts and runs for 3 seconds to pressurize the main line. At the same time you turn the key ON, the THEFT light on dash will come on for 3 seconds... then go out after recognized... see that this happens also.
Old Jul 26, 2017 | 04:20 PM
Lloyd62's Avatar
Lloyd62
Thanks everybody. I finally got it started. It was a loose connection in a pigtail splice I had to replace. Small problems create large headaches!
Old Jul 26, 2017 | 04:51 PM
redfishtd's Avatar
redfishtd
Does it continue to run after shot of ether ?
PCM power relay controls Fuel relay coil , fuel pressure rail sensor reports to PCM temperature and pressure. . Pcm gives permission to FPDM module on rear axle to run as a drive signal . Pcm allows fuel pump relay to give main power to fpdm module but only thru crash switch .
Fpdm gets its ground off axle , I would clean it . You haven't talked about fuel filter change it , Maybe put temp . hose on engine side into pan and see if it pumps into pan .
Depending on your tests and answers , you know you are bypassing injectors with spray . Pcm supplies grd to injector it wants to come on the other side is hot with key and jumps from injector to injector . Are they all standing hot .
Old Jul 26, 2017 | 04:52 PM
redfishtd's Avatar
redfishtd
I just saw you fixed it
Very complicated drawings for fuel pump circuit ,it goes thru many diagrams.
Old Jul 27, 2017 | 08:47 AM
alloro's Avatar
alloro
Pigtail going to what?
Chris Skoglun
46
Mar 30, 2017 01:31 PM
Bill Towne
Modular V8 (4.6L, 5.4L)
Jan 29, 2016 02:36 PM
joewizl
2004 - 2008 F150
May 16, 2015 08:48 PM
marc21387
Jun 18, 2012 11:15 AM
Rus01
Oct 23, 2010 05:41 PM
