Ball joint choices
Old Mar 30, 2018 | 07:14 PM
mmenzies's Avatar
mmenzies
Ball joint choices
My ball joints are loose again after replacing with Motorcraft less than 50K ago
choices
motorcraft. $200
Moog $135
proform $150
Dynatrac $590
head says Dynatrac but the wallet is squeaking at the huge difference. are there other alternatives and what is the general consensus.. the thought of a plastic insert in this heavy duty part doesn’t make a whole lot of sense, at least the moogs have a hardenedpowdered metal gusher bearing
thoughts please
as always thanks in advance Mark
Old Mar 30, 2018 | 07:54 PM
F0rdF0rever's Avatar
F0rdF0rever
I just did mine a few weeks back. I used XRF ball joints. They were highly recommended here.
Old Mar 30, 2018 | 08:04 PM
bismic's Avatar
bismic
100k on my DynaTracs. Love them.
Old Mar 30, 2018 | 08:09 PM
tfunk88's Avatar
tfunk88
I only have 35k on my Dynatrac’s, but I’m happy I went with them...so far.
I’ve had issues with Moog U-joints and tie rod ends. Good thing they have a lifetime warranty and are easy to replace for the steering, but that won’t cover labor for ball joint replacement if they go bad again.
Old Mar 30, 2018 | 08:41 PM
Per4mance's Avatar
Per4mance
XRF for the win, cheaper than Moog and million miles warranty.
Old Mar 31, 2018 | 03:58 AM
Yahiko's Avatar
Yahiko
I second the XRF.
Old Mar 31, 2018 | 07:02 AM
TooManyToys.'s Avatar
TooManyToys.
135k on OE (Dana/Spicer), 80k on Moog, when Moog was Moog.
Left lower joint failed due to water and dirt intrusion after the boot failed by cracking.
Old Mar 31, 2018 | 03:40 PM
Sullid01's Avatar
Sullid01
+1 for Dynatrac. I just put them on. Very solid. I could not do it with a standard 6" c-clamp though. I needed to get a larger c-clamp - 9" throat on Amazon for $90. The first side I took to a tire shop and they pressed them in for free which was nice. The other side I got the larger press for. A 7" clamp would work. Dynatrac are a bit taller and need a few special collars which add to the throat size needed to do the whole press properly
Old Mar 31, 2018 | 10:07 PM
78fordman's Avatar
78fordman
I have had good luck with XRF
Old May 5, 2018 | 10:16 AM
mmenzies's Avatar
mmenzies
choices
motorcraft. $200
Moog $135
proform $150
Dynatrac $590
thoughts please
called to purchase Dynatracs and I was already squeeeking at the cost. They told me that they went up last week to $640 due to the steel price increases tarrifs. This is hogwash. 4140 has not increased by $1,500 per 100 lbs ($30,000 per ton).. they were already way overpriced compared to everything else and I just felt they were giving it to me with KY jelly so I declined.
any other good recommendations
Mark
Old May 5, 2018 | 11:04 AM
tfunk88's Avatar
tfunk88
Mark
Overpriced depends on what you get. I had two sets of ball joints (Motorcraft, Moog) last less than 40k miles each. My Dynatracs are now at over 60k miles and have absolutely zero play...and for the last 30k miles I've lived off a dirt/gravel road. And my Excursion is lifted with wide wheels/tires. So from my experience I recommend them.
Old May 5, 2018 | 11:20 AM
Sullid01's Avatar
Sullid01
I did the dynatracs. Yes they are expensive but the job is labor intensive and not a whole lot of fun. I would still pay the premium. Plus they had the courtesy to use KY
FWIW, XRF seemed to be the forum favorite economical choice when I was researching it.
Old May 5, 2018 | 09:13 PM
mastersativa's Avatar
mastersativa
I always run moog, they are lifetime warranty, and the job is really not that labor intensive. Of course I do that for a living, lol. I don't have experience with dynatrac but the forum sounds as though they are pretty good, they sure better be for that price, I can put in five sets of moog for one set of dynatrac. And yes I have put in two sets of moog on my 03 250, but it is a plow truck, carrying a 9 and a half foot western v blade, and I do drive it like I stole it. Is also a gasser. I just put moog in my 06 350 diesel, so I guess I will see how they differ in longevity.
Old May 5, 2018 | 09:30 PM
Yahiko's Avatar
Yahiko
Are the Dynatrac the ones that can be rebuilt?
Old May 5, 2018 | 11:13 PM
Sullid01's Avatar
Sullid01
yeah, the dynatracs can be rebuilt. It saves some money over buying a new pair but it takes about 2-3hrs to rebuilt all 4. The rebuild kit is not exactly cheap either.
