Balancing beads
Old Mar 30, 2018 | 07:54 PM
tibadoe's Avatar
tibadoe
I use the beads in my trailer tires -- I like them and will continue to use them.
Old Mar 30, 2018 | 07:59 PM
04TXLightning's Avatar
04TXLightning
I am seriously considering using them. I will go with counteract if I do. Been doing a lot of research. I have 35x12.5x20 Ridge grapplers
Old Mar 30, 2018 | 08:13 PM
cficare's Avatar
cficare
That reminds me of another observation. I've had a couple dual axle car trailers and noticed there were no shock absorbers ... but also noticed the wheels were not balanced (none of them had balancing weights). Do travel trailers have balanced wheels or are they allowed to shake the devil from the trailer?
Old Mar 30, 2018 | 08:33 PM
sbechtold's Avatar
sbechtold
Most trailers I've seen do not have balanced wheels. I bought a new equipment trailer a year ago and the wheels were not balanced. First thing I did was balance the wheels. I've had tires last longer on trailer once they are balanced (and no more shaking). I run beads (actually 10oz of Airsoft pellets in each wheel) on my rock crawler. Before you say anything it doesn't see much in the way of road miles and I've used them for years without any issues. They do degrade over time and they are easily changed. Tried Dynabead's but prefer airsoft pellets. Although I wouldn't run pellets on a daily driver.
Old Mar 30, 2018 | 08:49 PM
Mud Doc's Avatar
Mud Doc
For another option, check out centramatics.com Has worked real well on all 450s I have owned.
Old Mar 30, 2018 | 10:02 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I have used both the beads and the Centramatic balancers (not at the same time) with excellent results!
I am sold on the Dynabeads and will use them for every tire change in my future. The thing I really like about them, is that they will automatically adjust for mud/snow stuck on your wheel, chunked treads from gravel roads or offroad, or a rock stuck in your tire, etc... There are no ugly weights hanging on the wheel, or stuck to the inside to potentially fly off (had it happen once).
Old Mar 30, 2018 | 10:05 PM
JohnD333's Avatar
JohnD333
X2 on Centramatics.com for 450's and 350 duallies. Unfortunately had to buy new set for the smaller 350 bolt pattern. I got 100k miles on the 19.5's with great tread wear patterns and no balance shakes at all. I am at 60k miles on the 350, and will easily make 80k before needing tires. Zero steering or shaking issues.
Old Mar 30, 2018 | 10:35 PM
ford390gashog's Avatar
ford390gashog
I used beads and they effectively blasted my TPMS sensors and I won't make that mistake again.
Old Mar 31, 2018 | 04:30 AM
JeepPuller's Avatar
JeepPuller
I agree. I run Dynabeads in my 89 Jeep and my son's 91 Jeep. They are great on the Jeeps, but I do not know if I would run them in tire where a tpms sensor lives. Not sure how that sensor will like getting pelted frequently with all the beads.
Old Mar 31, 2018 | 06:56 AM
tibadoe's Avatar
tibadoe
The tires on my last two trailers came from the factory not balanced. The trailer would have a noticeable shake rolling down the road. When I replaced the tires I gave the beads a shot - solved the issue and super smooth.
Old Mar 31, 2018 | 07:46 AM
svtride's Avatar
svtride
Reading this post I was just thinking of the beads impact on the TPMS sensor...So in your experience they trash the sensor over time? How long did it take?
Old Mar 31, 2018 | 01:05 PM
masakimm's Avatar
masakimm
I have never seen a sensor damaged by beads and never seen a tire damaged by beads. the beads will not normally even come in contact with the sensor as it lives with the wheel and the beads are going to sit in the out side of the tires and once you start moving centrifugal force keeps the beads there. We have been using beads on vehicles for 7 years now and have never seen one failure caused by beads.
Old Mar 31, 2018 | 01:28 PM
  #28
redz284u's Avatar
redz284u
the instructions indicate beads are not to be used on runflat tires, and tires with sensors
Jafo56
May 11, 2018 05:44 PM
norman2012
Oct 16, 2017 06:15 PM
rockertom
All Things Towing
Jan 8, 2016 11:20 PM
A/Ox4
General Automotive Discussion
Nov 1, 2011 09:43 PM
SeannyBoy84
Sep 29, 2005 01:51 AM
