GVWR choices
Old Mar 30, 2018 | 12:38 PM
dnewton3's Avatar
dnewton3
GVWR choices
I have a specific question about the "option" of the 9,900/10,000 for the F250/F350 ....
What is the nature of this "rating" option? Is the purpose of this option to "rate" a truck downward in GVWR, so that a lower registration may be employed at the time of plating the vehicle?
This isn't an "up-rate" is it?
I don't care about the registration; I want whatever would give me the higher GVWR status. So if I order the truck, do I want this to "up-rate", or avoid it as a "down-rate" ???
Not sure how to interpret the "option" on the Ford site.
Old Mar 30, 2018 | 12:47 PM
Sunnyside42's Avatar
Sunnyside42
It's a paper reduction of the GVWR to avoid state level taxes and classifications on trucks. For example, in CA 15,000 GVWR (on a 350) forces a truck to be classified as commercial which jacks up the insurance and tag pricing.
Old Mar 30, 2018 | 12:59 PM
dnewton3's Avatar
dnewton3
Thank you; that's what I suspected.
Old Mar 30, 2018 | 01:14 PM
TheLex's Avatar
TheLex
One caveat. The flip side of that coin is even though your truck is likely capable of a going over the GVWR, if you do so and have an accident and then are found to be overweight, you may have some legal culpability.
Old Mar 30, 2018 | 08:41 PM
kkirt1's Avatar
kkirt1
I have read that a lot but think it would be more likely you would have some risk if you were overweight of the licensing requirements in your state. I'm not trying to start a fight but the games played with GVW for the sole reason to regulate commercial vehicles drives me crazy.
Old Mar 30, 2018 | 09:49 PM
TheLex's Avatar
TheLex
Oh I agree with you. Neither of those scenarios would be desirable.
Old Mar 31, 2018 | 07:33 AM
Clubwagon's Avatar
Clubwagon
In my area it isn't licencing it's the HOA C&Rs. Many HOAs prohibit you from parking a truck with a GVWR of more than 10K lbs at your home. In practice it means that most 350/3500 trucks are over the max while 250/2500s are under.
I found out about this after buying an F350 a few years ago. I had one person complain and managed to hold off any enforcement until I traded it on my current F250.
The purpose of the rule is to prevent somebody from keeping a commercial truck parked in front of their $million+ home. But there is always some jerk that sees the F350 badge on the fender of somebody's $80K Platinum and doesn't care about the actual purpose.
Old Mar 31, 2018 | 09:24 AM
951 DAN's Avatar
951 DAN
All pickups in California are registered as a commercial vehicles. As long as your pickup has a pickup bed that is less than 9 feet and the truck has a GVWR of 11,500 or less you are exempt from having to get a weight sticker, CA numbers, motor carrier permit, commercial insurance policy, and DOT numbers. It's on the CA website. If you have a pickup with a bed, registered to a company you are exempt from the weight sticker, CA numbers, motor carrier permit, commercial insurance policy, and DOT numbers as long as the vehicle has a GVWR less than 10,000. If its more than 10,001 you have to get all that stuff. So the 9,900 GVWR matters to companies, not so important for personal use.
Old Mar 31, 2018 | 01:52 PM
TheLex's Avatar
TheLex
Weight sticker? My F450 is registered in California and I don't recall having a weight sticker other than having to have it weight at the scales to establish the actual weight. But then again, I did state the vehicle is for personal, not commercial use.
claf
N. California Chapter
Oct 20, 2018 05:09 AM
nullop
Feb 9, 2018 10:30 PM
williamsauls
Nov 16, 2016 10:21 PM
Tnriverside
Sep 16, 2015 10:13 AM
galaxyfe
6.4L Power Stroke Diesel
Nov 27, 2009 12:37 AM
