Fast flow diesel....
Old Mar 30, 2018 | 09:39 AM
Awaldrup's Avatar
Awaldrup
It seems like my 16 took fast flow diesel better than my 17. Does anyone know if they have changed something?
Old Mar 30, 2018 | 09:50 AM
17350kr's Avatar
17350kr
My 06 was terable. My 11 was excellent and my 17 is just ok. Stops a couple times but wait a second or two and you can go for quite a while again.
Old Mar 30, 2018 | 10:07 AM
troverman's Avatar
troverman
Maybe it depends upon the pump. I fill up at an Irving truck stop using the high-volume nozzles and have no issue until the tank is nearly full.
Old Mar 30, 2018 | 12:32 PM
951 DAN's Avatar
951 DAN
My 2017 can't handle the high flo
Old Mar 30, 2018 | 12:35 PM
tony m 6.7's Avatar
tony m 6.7
Mine's fine with the high volume nozzle. Maybe it depends on the individual nozzle's condition.
Old Mar 30, 2018 | 12:36 PM
mrgrayaz's Avatar
mrgrayaz
High Volume nozzle, but only on the first detente. Still fills up pretty quick!
Old Mar 30, 2018 | 12:54 PM
wrvond's Avatar
wrvond
If I have it twisted to the side just a little bit, the pump will shut off in short order. Get it in straight and it's good to go at the high flow rate until nearly full.
Old Mar 30, 2018 | 03:57 PM
tortue71's Avatar
tortue71
No problem with mine either , maybe the 48 gallon helps
djed
Sep 25, 2016 12:02 AM
Stroker09
General Diesel Discussion
Jul 2, 2008 06:29 PM
motocaptain
Jun 23, 2008 09:34 AM
Smokin'
29
Aug 9, 2006 05:05 PM
96ford4x4turbodiesel
Oct 18, 2005 12:47 PM
