2015 multiple electrical malfunctions.
Old Mar 29, 2018 | 04:16 PM
Deanmc's Avatar
Deanmc
Unhappy 2015 multiple electrical malfunctions.
First off I am new here and thanks for allowing me into the group.
I have a 2015 XLT 6.7 4x4 crew with 230,000km that was running perfectly when I parked it last night. This morning it wont crank, fuel pump doesnt work, blower motor doesnt work (on any speed), i have several warnings on dash including, service advancetrac, trailer brake control module failure.
I assume that I have lost power or ground to these functions. I have checked fuses both under hood and in cab but do not see anything that is burnt. nothing in the manual is labeled for this group of functions.
Its a long weekend and the ford dealer here cant even look at it until Wednesday. Anyone have a similiar experience that could help give me some direction as to what to check next?
Thanks
Dean
Old Mar 29, 2018 | 04:45 PM
swarf_rat's Avatar
swarf_rat
No experience, but if there are multiple unrelated failures, I'd look to grounding of the PCM and other computers (BCM etc.). If that ground connection goes bad and the ground floats up, you will light up the codes like a Christmas tree as everything else is referenced to ground.
Old Mar 29, 2018 | 05:14 PM
69cj's Avatar
69cj
Thanks
Dean
Not to over simplify your problem but, did you check the battery voltages and cables. The battery connectors on these are subject to bad connections if not serviced regularly. The cables can also corrode under the insulation at the connectors.
Old Mar 29, 2018 | 09:36 PM
cappa's Avatar
cappa
I would check out the connector by the e brake if you use it often. Sometimes they come a little loose and wreck Havok
Old Mar 30, 2018 | 08:34 AM
cangim's Avatar
cangim
This was my first thought, I had hvac not connect and be inop until shut down and open door, then when turned back on it came on. Reseated this connector and thus far no issue, though I do expect it to come back at some point...
Old Mar 30, 2018 | 02:51 PM
golfmedik's Avatar
golfmedik
This is the culprit of many episodes such as you described. Ford has a TSB out about it. Sometimes that connector has to be replaced.
Old Mar 30, 2018 | 09:25 PM
ciscofreak's Avatar
ciscofreak
Had this exact issue on my 13. It's a chafing wire down by your e-brake.
Old Mar 31, 2018 | 04:35 PM
Deanmc's Avatar
Deanmc
Smile
Ding, ding,ding! Bad cell in the passenger side battery. these new computer controlled vehicles do strange things when a battery is bad. Thanks everyone.
Old Jun 20, 2018 | 05:56 PM
Karson's Avatar
Karson
is there a photo of this harness or something visual i can look at. Dont know if i've got tge right one or not?
ken1417
Apr 19, 2021 10:17 PM
Heidrich1969
6.2L V8
Jun 2, 2017 09:45 PM
georgieboy
1983 - 2012 Ranger & B-Series
Jul 15, 2013 01:26 AM
jasonhamilton1978
1997 - 2003 F150
Jun 29, 2012 11:12 AM
biederboat
Aerostar
Nov 17, 2004 04:11 PM
