2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
breaks
Old Mar 28, 2018 | 04:56 PM
simmonstn's Avatar
simmonstn
breaks
ford expedition el 2010 ,brake pedal drifts to the floor after stop with light pressure on brake pedal, also rear brakes are wearing much faster than the front. could there be an ABS problem
Old Mar 29, 2018 | 12:56 PM
alloro's Avatar
alloro
If you're losing brake fluid it's a leak, if not then it's the master cylinder. In either case it likely not the ABS.
Old Mar 29, 2018 | 03:47 PM
simmonstn's Avatar
simmonstn
I just had the master cylinder replaced. Also, all brake pads were replaced. Prior to replacing, the back brakes were somewhat worn with only glazing of the front pads which had no wear. No leaking fluid.
Old Mar 30, 2018 | 01:39 PM
alloro's Avatar
alloro
Could be a bum master cylinder.
Was it fully bench bled prior to installing it?
Were the brake lines bled after installing the new master cylinder?
thompsdw
Dec 28, 2012 08:12 AM
lvflyer
Jan 24, 2008 12:04 PM
LTCPipkin
Aerostar
Aug 11, 2007 08:45 AM
pdqtimetrialer
Dec 29, 2005 07:18 PM
D_STICK
1978 - 1996 Big Bronco
Jul 14, 2001 01:01 AM
