Warranty Issues
Old Mar 27, 2018 | 01:39 PM
lancetowrig's Avatar
lancetowrig
Warranty Issues
Hopefully, I will be able to get an answer on here..... I have a 2017 F-350 Platinum, I took it in for some warranty issues last week and left it there for three days, nothing was repaired. I have a very annoying rattle that seems to be coming from my B pillar. I've taken all the interior trim off of that area and couldn't find anything loose. I notice it at low speeds going over bumps (in and out of the driveway / hitting a manhole cover in a neighborhood). Has anyone else experienced this or know the fix? Also when it's raining or after a car was every time I hit the brake pedal I get a trailer connected/disconnected warning on the dash and sometimes it will tell me there is a turn signal out on the trailer that isn't even connected. When I'm towing my fifth wheel in the rain I don't have this issue and my best guess is that water is getting 7 pin connector on the bumper. Any advice on how to get these things corrected would be greatly appreciated or tips on not letting the dealership jerk me around and keep my truck for 3 days and not fix anything would also be nice.
Old Mar 27, 2018 | 01:47 PM
seville009's Avatar
seville009
Regarding the rattling, from my own experience, check the rear shocks. If you grab them, they should not move. I’ve had the top bolt of my shocks come loose twice.
If that’s not it, release and then slam back the rear seats in case they are not latched tight. Check any and all bolts. I had an annoying metal on metal rattle that drove me nuts - finally found loose bolts and washers in the fold down tray of the rear seat.
Old Mar 27, 2018 | 02:05 PM
diblasi's Avatar
diblasi
Trailer issue after contact with water there is several threads on here about the connection under rear bumper not sealed right and water getting in casing those trailer issues. Check connections in rear. The only rattling issue I've had was on my 15 sounded like it was coming from a post though. Turns out they forgot to put sound damper over fuel injectors.
Old Mar 27, 2018 | 02:09 PM
diblasi's Avatar
diblasi
https://www.ford-trucks.com/forums/1...-messages.html
and FYI I would call ford customer relations department if you think your getting the run around from your dealer and get a CAS #.
Old Mar 27, 2018 | 02:21 PM
Buliwyf's Avatar
Buliwyf
I'm back logged a week. And I'm an emergency service tech. I still can grab a night job here or there, or something on the way home. But warranty stuff for us is 8-4 only.
Yeah, the auto industry sucks. But Hyundai is doing awesome. In and out in a few hours. Then again, all of their cars are exactly the same trim level.
Old Mar 27, 2018 | 03:36 PM
BigStu59's Avatar
BigStu59
The electrically issue sounds like the TSB that was issued by ford last year. It’s for the Job 1 trucks built in 2016 and early 2017. The harness connectors allow moisture to intrude on the connections. This will cause false readings and the tailgate to drop. In this forum there are a few detailed threads about this issue.
Old Mar 27, 2018 | 06:05 PM
stewy604's Avatar
stewy604
I had a rattling issue like this, turned out to be two fold. 1) Both the rear seats were not properly latched; and 2) I tightened up ALL the doors with electrical tape on the catches. Quick and easy fix, but nothing I accept on a $80K truck.
Old Mar 27, 2018 | 06:25 PM
jbrnigan's Avatar
jbrnigan
sorry, duplicate post
Old Mar 27, 2018 | 06:29 PM
jbrnigan's Avatar
jbrnigan
And, this goofy reply helps the poster with a serious warranty concern HOW?
Old Mar 27, 2018 | 08:15 PM
VA13FX4's Avatar
VA13FX4
For me the rattle near the B pillar was the door latch not fitting tightly against the striker. The dealer thought it was a bushing in the latch but replacing that made no difference. Even though they gave me the truck back saying it was fixed. I loosened the striker and moved it inward. It only had a couple mm of movement but it made a huge difference. A couple wraps of electrical tape on the striker eliminated the rattle all together.
Old Mar 28, 2018 | 11:08 AM
Buliwyf's Avatar
Buliwyf
Hopefully it helps him be patient.
It ain't going to get fixed in one week, with 3 dozen broken trucks in the lot. Ford is finding more new and interesting ways to screw up their trucks, than the service techs can keep up with.
Old Mar 28, 2018 | 12:23 PM
Rustyfan21's Avatar
Rustyfan21
On my 17 Super Cab I had a rattle like that and it drove me nuts, finally realized that if I had a passenger and after they got out and did not return the seat belt buckle back in its proper place, against the loop of belt material, it would rattle against the door frame.
Old Mar 28, 2018 | 12:28 PM
f350ktm's Avatar
f350ktm
I had a banging sound coming from the B pillar on the passenger side. Turned out to be the metal side of the seat belt latch banging against the plastic trim.
Turning the seat belt around to point towards the soft seat eliminated the problem.
hinsong
Apr 14, 2019 06:54 PM
JetFuelBurner
All Things Towing
Mar 14, 2018 08:44 PM
JetFuelBurner
Feb 24, 2018 01:45 PM
250kz
Aug 23, 2010 04:09 PM
mc20031
Electrical Systems/Wiring
Jul 25, 2010 11:39 PM
